Help with Wideband
Help with Wideband
Hey guys, I already know our cars have a "wideband" from the factory (as I've done my research a little), but my question is, I have the AEM UEGO Wideband and was wondering how I go about wiring it up? I know the power and ground and the backlight, but the other wire goes to the purple wire on the 02? Or does it go somewhere else?
If we're talking about the UEGO gauge type...
All you'll need is the power/ground. As I recall the white wire is an analog out (not used) and the blue wire is a serial out you can hook to a computer. The other connector is dedicated to the sensor harness. If you're talking about the UEGO box, ... never had one so I dunno
If you're trying to use this on the Factory O2 sensor on the turbochargers o2 housing, major failwhale... DO NOT attempt to do that.
I have the same thing. I emailed ZZP about whether or not I would have to do the whole "add an O2 bung" to the DP for this and you will. Everything that comes with the gauge is all you need. You'll have your two wires for power/ground and the other two are for data logging and stuff like that. They aren't needed.
n20saturn
Sep 30, 2015 12:26 AM
