heres a video of my new issue
just a brief explanation, it seems the bypass valve is leaking after 10 psi. but it ran right for about 5 mins after the new intercooler was installed.
Cobalt SS LNF boost issue - YouTube
i did and that was an issue do to the cracked weld on the old intercooler and then i took everything loose and retightend everything (every silicone boot all the way from the turbo to the intake) checked the map sensors for a leak around them, check the block off for a bov and on top of that im not throwing a code either.....when i had a cracked ic it threw a 101 code
Check the coupler to the hotside of the intercooler. I found out the hard way if you scrape you'll push the intercooler back making it push the silicone coupler up to the frame seam and cutting it. I did not hear this boost leak.
yea me and my buddy is gonna take a look tomorrow evening that is a good point tommy it probably is torn.lol. hey I gotta question for you since you have an evo, they have the td04 turbo stock right? basically the same as a k04 but anyways where can i get a block off for the bpv and run my bov again....Believe me ive searched with no luck at all
i seen on an evo site where a guy took out the bpv and flipped the diaphram over and reinstalled. said instead of trying to stay shut its forced shut....would this mean it would still function or does it mean this would block it off and ill check that hotside boot fasterisbetter
me either man but i think i just found my solution
TD04 Turbo Block Off Plate: Synapse Engineering Outlet
I wouldn't be so sure that they're bypass valve (or block off plate) is the same size. I thought I remember somebody bringing this up a month or so ago and the plate was the wrong size.
for real? cuz i had a block off for my k04 and it was too small, this one is the same as far as the shape and design but i cant say much for the actual size....think you could find that post?
Check to make sure the vac tube that goes to your coldside pipe has not come off at the coldside pipe nipple, right next to the TMAP sensor.
Also, if you install a block off plate, you have to use the diaphragm as a seal, anyway, so it it's torn around the edge. you'll have to buy a new one, anyway.
Another question: Does the TD04 perform as well as the K04? I have a TD04 as a spare, in case I blow my K04. When I bought it, I didn't realize that it wasn't a K04, but I'd like to keep it instead of re-selling and buying another K04.
Yet another question: Which IC did you end up going with?
What about this one??
Cobalt Turbo Kit, Diverter Valve, Bypass Valve Block Off Plate- TREADSTONE PERFORMANCE
