High Pressure Fuel Pump Replacement
Old Feb 28, 2018 | 03:48 PM
tomj77's Avatar
I should for ***** and giggles ask how much it would cost at dealer
Old Apr 24, 2019 | 12:23 PM
CudaJoe's Avatar
Thread revive: I am going to be replacing this next week. Ordered a new HPFP and high pressure fuel line from rockauto.
Now question that hasnt been really answered in here, do I need to remove the roller to clean and relube or can I skip doing that and just replace the pump? 2nd question, no one has mentioned the torque specs for tightening the fueline and mounting bolts? What are the recommended torque specs?
Old Apr 24, 2019 | 05:59 PM
Kolt's Avatar
Don't have to but id recommend it, i do it for any car I take the pump out of. I would recc consider also just getting a new one since it is a roller bearing that is under a lot of force just to be safe. High pressure mounting bolts are torque to yield technically, and are supposed to be replaced with new bolts. Thread bores should be clean and grease/oil free and new bolts get blue medium strength locktite. Bolt torque on the pump bolts is 71inlbs and then 50*. Your cam needs to be turned where the roller will rest on the center of a flat between lobes before installing the pump and tightening the bolts that way you don't bind and damage the pump when installing since you will be compressing the spring for the pump. Fuel rail feed pipe fittings (pump to rail) are torqued at 24ft lbs. Fuel pump feed pipe (tank to pump) is 22ft lbs.
Old Apr 24, 2019 | 06:36 PM
C0balts5's Avatar
What do you mean relube the roller?? Everything is lubed with engine oil, the o ring and gasket are a must so that you don't get an oil leak
Old Apr 24, 2019 | 06:43 PM
Kolt's Avatar
True but its good practice to take it out and clean the old oil and carbon build up on it and the bore. Then oil it on both sides with something like lucas or assembly lube. Also you lube the new o ring but not the metal gasket.
Old Apr 24, 2019 | 06:53 PM
C0balts5's Avatar
Gotcha. Probably should have do that to the roller. Didn't see no junk or anything obvious, probably because I change the oil every 3000 miles
Old Apr 24, 2019 | 07:03 PM
Kolt's Avatar
Usually its pretty clean when I have customers that do that but even then there is some buildup sometimes. Also the spot that the pump rests on the back side of the roller also wears over time. Idk how much it has to wear to cause issues but if I see one that is indented I replace it.
Old Apr 25, 2019 | 09:22 AM
CudaJoe's Avatar
Very helpful Kolt, thank you. I will add a new HPFP roller to the order.
Blasirl
Jun 10, 2019 11:38 AM
Shanman
Dec 11, 2016 11:51 PM
bucks121
Sep 12, 2015 07:39 PM
NickD
Mar 19, 2013 10:24 PM
SKDR112888
Jul 21, 2007 06:26 PM
