a how to????
Old Mar 18, 2011 | 07:19 PM
jaygo7007's Avatar
a how to????
i just bought a new model forge motorsport bpv and was wondering is there a how to? i thought i read one on here but cant seem to find it anymore
Old Mar 18, 2011 | 07:31 PM
slvrred-'s Avatar
i just put mine in today. Just remove your intake, you don't have to but it gives you more room. Then remove the 3 10mm bolts and the vaccum line. Put forge in. put the 3 bolts back in. hook up vaccum line. reinstall intake. done.
Old Mar 18, 2011 | 07:35 PM
jaygo7007's Avatar
does it have to face a certain way???
Old Mar 18, 2011 | 07:48 PM
Iam Broke's Avatar
Slot down into the turbo bypass duct. Look when you have the stock one out, you'll see what I mean.
Make sure the thin o-ring stays in place if you open up the Forge BPV cap snooping around.
Old Mar 18, 2011 | 08:02 PM
094doorSS/TC's Avatar
Make sure you clean the old loctite out of the bolt threads, before you reinstall the new BPV.
Old Mar 18, 2011 | 08:36 PM
jaygo7007's Avatar
thanks guys will install first in the morning. gotta get ready for the hpd meet
Old Mar 18, 2011 | 10:14 PM
Cavalierssr's Avatar
Mine was cut where does it go? I'll have to find a replacement.
Old Mar 19, 2011 | 04:21 PM
seeyaass's Avatar
I want a forge but cant find where to order it!!
Old Mar 19, 2011 | 04:31 PM
BPacak's Avatar
Vtec Rep
Forge Diverter Valve 08-10 Cobalt Turbo - Blow Off Valves - Forge
Old Mar 19, 2011 | 04:38 PM
Iam Broke's Avatar
There is a thin relief under the cap that the o-ring goes into. You'll prob have to get it from Forge. It won't seal properly without the o-ring.
Old Mar 19, 2011 | 08:09 PM
seeyaass's Avatar
Thanks bpacak
Old Mar 20, 2011 | 12:57 AM
That's what I figured. I'll hit 'em up on Monday.
Old Mar 20, 2011 | 08:00 PM
Baron7700's Avatar
thought about getting one, but im not sure how necessary they are. I have 23,000 on the clock, and i have been switching back and forth between gms1 and a 360wtrq byt tune. I literally took my bpv off yesterday to check it and it looked brand new. K/n is loud as f*ck as it is now so why need to be louder haha
