How to hit certain 1/4 times
cool, so u just went with the downpipe instead of the whole exhaust system huh? Did u get both the cold and hot side for the charge pipes? I only got the hot side. LOL I read that the cold side is good already from factory. What kind of intake u running? I got the CAI from Dejon with the recirculation option but I'm currently not recirculating the air from my BOV. Instead the just used a rubber stopper and plugged the hole on my intake. LOL Before I did that though, I used to just run it with the stock box but with a K&N drop in air filter. In my opinion, I think it ran better that way. However, with my CAI it sounds so much more beast. LOL But I honestly think it runs better with the stock box k&n set-up.
If u don't recirc or tune for it u are loosing metered air and running rich and bogging more than likely in between shifts. I'm also debating on a tune hp or switchable trifecta. Got a great tuner here in Ontario. Met once years ago but never tuned from him. He is a trifecta and hp tuner guy, so just debating in my head
Sent from my iPhone using CobaltSS
Hmmm, now I'm considering going 23psi tune. LOL when I get in touch with Trifecta I'll ask what they recommend. I want a reliable car that will smoke most ricers. LOL believe it or not, I lost to a single cam turbo civic!
He's a friend of mine and is making 190 hp. He has street slicks and took me by about 2 and a half to 3 car lengths. He obviously took me from the start and pulled all the way. It wasn't until 4th gear that I started creeping up. We were well into triple digit numbers and decided to slow down. LOL I felt ashamed. LOL
What I was stating previously is, with 110-111 traps you will be in the 12's with good traction. The balts have pretty tight gearing, so Trap speed and traction are the big variables.
,or maybe because his car is 700 hundred pounds lighter than mine, he's turbocharged too, has street slicks, upgraded clutch, basic bolt-ons, and tuned. Or most likely both. LOL ****, I'm just waiting on that tune. Still saving up for it. LOL I'll run him again once I get tuned. Probably not from the dig though. LOL
Just curious, does anyone uses the no-lift shift feature going from 1st to 2nd gear? The previous owner of my car must have done it incorrectly too many times or something because when I shift to second gear, it's hard to go in. It doesn't go in smoothly like all the other gears. I usually only use NLS when shifting from 2nd to 3rd because I don't wanna risk it going 1st to 2nd due to that issue. I'm scared I might mess up the transmission. LOL also, a lot of people say that using NLS from 1st to 2nd is not worth it. Any comments on this? Also, for all those of u that are tuned, can or do u guys still use NLS? Is it still safe?
I thought about it but I like the stealth feature. LOL Don't want my car to always be on kill mode. Only when I go racing. Unless HP offers that option. However, I did see a video of 2 ss/tc racing with just the tunes. One from HP and the other Trifecta. The HP won. Not sure if driver mod is needed or if HP is simply better but I'm sticking with Trifecta unless HP offers stealth mode.
I also think there's no real good reason not to recirc your air, especially on a car you dd. The only thing it does is goofs with the A/F mixes when your valve opens.
You can get hp tuned and just not beat on it like it would it would if you're running trifecta. It's really simple though. I'm just trying to steer you away from regretting something in the long run like I did. I spent $350 on trifecta tune and cable. I upgraded something's and went bigger turbo and to get retuned I would've had to end up paying another $250. If I would've went with hp, it would've just been the credits ($100) and ($150-200) for whoever tunes you for free whatever you do regardless of what you do just as long as you can get your hands on an hptuner suite. If not, you can always buy the suite and basically rent the tuner for $100 or so to others.
