How much boost can stock LNF hold?
Old Jan 15, 2014 | 11:03 AM
Joe09SS's Avatar
I was looking around the forums couldnt find the answer to a couple questions..
In your experiences, how much can the stock motor hold for boost with the stock turbo.
As I read I pciked up on a few things that i know i would have to upgrade, but mostly just bolt ons. I already have intake and about to buy a ZZP catless DP, soon to buy full catback too, but would I also need to upgrade intercooler and charge pipes?
of course ill need a tune but do you think it'll be able to hold 23-25 psi
Old Jan 15, 2014 | 11:07 AM
Gelladuga69's Avatar
How much boost could a lnf boost if an lnf could boost.
More boost than the K04 could put out. 24 psi is about the most you wanna go on K04.
Old Jan 15, 2014 | 11:13 AM
umrdyldo's Avatar
Done in first post.
24 psi for best performance/efficiency is what we have all about settled on.
Old Jan 15, 2014 | 11:41 AM
r3v07ut10n's Avatar
hold... ~19psi @ redline, i ran peak 25.5psi with no issues at all.
Old Jan 15, 2014 | 11:54 AM
Joe09SS's Avatar
Okay I was planning on running 23 max to be safe but maybe I'll do 20. Not to sure yet. If I upped the psi would I 'need' to upgrade the intercooler and piping?
Old Jan 15, 2014 | 11:55 AM
Cobalt_Daddy's Avatar
22-24 does seem to be the magic number.
Old Jan 15, 2014 | 12:31 PM
Joe09SS's Avatar
Even with stock intercooler and piping?
Old Jan 15, 2014 | 12:38 PM
r3v07ut10n's Avatar
stock IC might or might not pop lol. Mine finally did after about 30k KM. Stock piping is fine. 20PSI if your racing as a DD 22-24 as what most people say. Biggest question i have is, are you tuning with HPT or TFT?
Old Jan 15, 2014 | 12:42 PM
Joe09SS's Avatar
Its gonna be a DD. And I'll probably just upgrade eventually Lol and it'll probably be a HP tune and possibly a street tune not dyno idk yet
Old Jan 15, 2014 | 12:48 PM
umrdyldo's Avatar
Stock intercooler and stock upper charge piping are a good idea. intercooler will for sure blow, many/most get by the stock charge pipes.
Old Jan 15, 2014 | 12:50 PM
Joe09SS's Avatar
Alright. Might as well upgrade the stock pipes too Lol make it look a little better under the hood. Nothing like looking at oval pipes Haha.
Old Jan 15, 2014 | 01:58 PM
Tuning is limited. As there's two major platforms to go with. HP Tuners and Trifecta. Just do your research on both, but HPT is more robust and preferred.
Would recommend an aftermarket IC to keep IAT down, but stock pipes aren't a problem, perse.
Old Jan 15, 2014 | 02:16 PM
taintedred07's Avatar
Get the intercooler and charge pipes before the catback
Old Jan 15, 2014 | 06:02 PM
Originally Posted by taintedred07
get the intercooler and charge pipes before the catback
x2
Old Jan 15, 2014 | 06:35 PM
tomj77's Avatar
except they burst.
Old Jan 15, 2014 | 06:39 PM
tomj77's Avatar
this is my recommendation. replace all plastic on the motor side of things. intercooler, intake, charge pipe. intake doesn't matter much since there is no pressurised air going through it but it sounds better and looks better with aftermarket. charge pipe have been known to split on higher than stock boost. not often but rather be safe than sorry. intercoolers have been known the break an end tank quite a few times, due to boost or cold temps and hitting a bump or something. and last but not least, if u really wanna be safe, replace ur rad as well, it also has plastic end tanks with plastic mounting pegs. I just broke mine and replaced it with an all aluminum one. others on here have also broke theirs. Those are all the concerns ull have with plastic crap on ur car as far as I know, now u can choose what u wanna do with this info
Old Jan 15, 2014 | 06:40 PM
tomj77's Avatar
I think there are very few running stock charge pipe.
Old Jan 15, 2014 | 06:52 PM
Steviodaddio's Avatar
Since everyone has thrown 20-24 around, Nate and a bunch of other guys had a really fun time correcting/proving me wrong since there's like 4 or 5 of them running 27-30 psi and holding just fine. After 24 you start to only see your torque increase but with 27 or 28 psi I think Nate said he was pushing 420 ft lbs and 330 (?) for HP. Tuning is key though. After 25 psi the K04 start's to get hot but you can benefit in my opinion.
Old Jan 15, 2014 | 06:57 PM
ampzor350's Avatar
Stock intercooler and pipes are fine on the stock turbo. I have ran them for 40k+ on 23-24 psi and have never had on issue.
Old Jan 15, 2014 | 07:20 PM
You're lucky, many guys have busted the plastic end tanks on the stock intercooler.
Old Jan 15, 2014 | 07:33 PM
Shortbus's Avatar
Sooner or later they will break is the point everyone is trying to make I think. It's a crappy design, and if you are gonna spend the money modding might as well replace plastic parts.
Old Jan 15, 2014 | 08:57 PM
SSlobalt's Avatar
Stock IC is horrible. Why chance sitting on the side of the road? Stock pipes are fine. I've been running them for 5 years with no issue. I don't go over 22 psi, btw.
Old Jan 15, 2014 | 09:28 PM
tomj77's Avatar
I'd like to know how long they been running the 28 psi
Old Jan 15, 2014 | 09:42 PM
lilskarvcx's Avatar
boost
I can vouch for stock parts on 23psi after ~30,000miles. Been to the drag strip a few times and hit peak boost quite often on the streets (nls included).
Old Jan 15, 2014 | 09:46 PM
The stock upper pipe looks so cheap. I can't wait to get my ZZP one on.
