How much oil 09 SS?
Old Apr 25, 2010 | 10:25 PM
JAYNO20's Avatar
How much oil 09 SS?
How much oil does an 09 SS take? I have an 06 SS which I know takes around 6.5 quarts, I am assuming the 09 takes less, why would the 09 take less than the 06?
Old Apr 25, 2010 | 10:57 PM
efactor's Avatar
5 qts. Thats it. Get some Castrol Edge also, best oil for our cars.
Old Apr 25, 2010 | 11:14 PM
JAYNO20's Avatar
why does the turbo ss take less oil than the supercharged ss?
Old Apr 26, 2010 | 03:34 AM
SSlobalt's Avatar
For one, it's a different motor.
Old Apr 26, 2010 | 03:49 AM
OneCOLDBIZL272's Avatar
5 qrts on turbo lnf's
Old Apr 26, 2010 | 09:56 AM
northvibe's Avatar
you can get 5qrt mobile 1 jug, so you just pour 1 jug and bam done although I've only found it at walmart which...I have a hard enough time parking near.
Old Apr 26, 2010 | 10:12 AM
blackbolt89's Avatar
ive only been able to find a "5+" jug which is 5.25 quarts. lol. would the extra 8 ounces harm anything?
Old Apr 26, 2010 | 10:22 AM
SeanEE89's Avatar
I wouldn't take any chances by adding more then it asks for. Which oil you use is completely based off of opinion anyways. Everyone has their own view on whats best. Some like to stick with what GM recommends which is Mobil 1 others like to switch to oils like Royal Purple. Personally I just stick to Mobil 1, but I'm tempted to switch to AMSoil.
Old Apr 26, 2010 | 10:29 AM
northvibe's Avatar
weird, Um well when I fill mine with 5qrts it shows 1/2 way on the dip stick so what you want to do is add most of the jug, ie. 5qurts. run the car to get the oil moved around, shut off car, check dip stick and see where it is at. if its 1/2 way on the dip stick dont add more, but if its lower you could. You can save the old oil for lube, or stock pile it for use later in topping it off.
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
