how to remove charge pipe bolt
Old Mar 6, 2010 | 04:15 PM
northvibe's Avatar
I have it half off, the injen instructions suck. The bolt that holds the hot side charge piping to the engine, has some metal cover over a bolt and rubber. how do I get that off?
Old Mar 6, 2010 | 05:09 PM
Stephenishere's Avatar
Yeah I agree, not the best instructions. I actually just installed my piping about an hour ago too! I also struggled getting that bolt out of the stock engine due to the angle and what not. What I did was took a pair of needle nose pliers and bit by bit ripped apart the rubber piece inbetween the clip and the actual piping bracket. Once i ripped off a good deal of it, the whole piece simply lifted off with a little tug. Since the bolt was still in there I used the pliers again and was able to unscrew it off. I figure even if I were to put the stock one back on that I really don't even need that screw anyways.
This guide is pretty decent too, https://www.cobaltss.net/forums/show...+charge+piping
Good luck! I'm amazed at how much better this car sounds with trifecta tune, dejon intake, and the dejon charge piping. The turbo spools much faster and has a much better power-band than before.
Old Mar 6, 2010 | 05:24 PM
09BlueBaltSS's Avatar
Take a small flat head screwdriver and lift up the little finger in the middle of the clip then take a small pair of needle nose pliers and pull it out.
Old Mar 6, 2010 | 06:52 PM
northvibe's Avatar
weird..so yeah the metal cover just slides forward, and the charge piping just pulls up... . went for a test run...didnt have the 1 connecting the lower and upper tight enough I guess and blew it on the hwy lol...hmm tightening time
Old Mar 6, 2010 | 07:56 PM
ecotecturbo's Avatar
Do you have the t bolt clamps?
Old Mar 6, 2010 | 08:01 PM
northvibe's Avatar
yes, dont think I had them tight enough, and the supplied injen silicon couplers are not long enough imo. I just ordered new ones.
Old Mar 6, 2010 | 08:26 PM
09CobaltSS1's Avatar
most folks with the injen cp seem to be having issues with the couplers. This is good to know seeing as how I plan on buying one of these puppies soon. Do you know what size diameter the couples are? Do you need ALL new couplers or only the ones that attach to the turbo and IC?
Old Mar 6, 2010 | 09:03 PM
northvibe's Avatar
imo they are all too short, but they can work if you do it just right.
I bought
1 x 2.0" silicon straight coupler
2 x 2.5" silicon straight coupler
2 x 2.0" tbolt clamps
4 x 2.5" tbolt clamps
I still love the injen, its cost effective, most direct route to IC AND I think you could almost change oil with out removing the pipe.
Old Mar 7, 2010 | 10:11 AM
RYRO14's Avatar
I sawwed that bitch off lol
Old Mar 7, 2010 | 11:10 AM
SSam2.4's Avatar
I know hair spry works well to keep couplers in place.This is used often on big trucks and seems to work well when used with good clamps.
Old Mar 7, 2010 | 11:34 AM
Gestapo007's Avatar
my Injen pipes arent causing me any issues. Have T-bolt clamps and Injen couplers that came with it. The couplers are big enough to do the job if you install them correctly. But if your more comfterble with longer ones then do what you gotta do. There great pipes though and i would recommend them to anyone. I remember some vendor complaining that the pipe is too thin or something and to buy there's as its thicker and more durable. Im pretty confident this pipe will handle anything I plan on throwing at it. I dont see me blowing this pipe up.
Old Mar 8, 2010 | 11:26 AM
wantedSS/TC's Avatar
clear image auto's CP were the best so far. their supplied t-bolt clamps are rigorous as ****. they've withstood the stock tune, 22psi tune, 30psi tune and now my 22psi tune without blowing yet. I keep a 7/16" and 12mm in my car just in case though ..
Old Mar 8, 2010 | 11:52 AM
northvibe's Avatar
I retightened it and havent had a issue since, I just dont know how tight to tighten the tbolts.. New couplers are on the way, but they arent needed. I just am **** on stuff and want lots of over lap. I'd buy the injen again hands down, cheaper and takes the shortest route.
Old Mar 8, 2010 | 01:21 PM
Gestapo007's Avatar
yea i hear ya. i felt the same way at first. but i had to take them off and reinstall them after a dealer trip and the 2nd time it went so fast and was so easy I was just like, ok, maybe they work just fine.
Old Mar 8, 2010 | 01:29 PM
yeah, there is a fine line between over-tightening and under-tightening them.
I tighten them til I have to actually tug on the bolt to move it tighter. anymore and it'll snap the clamp.
Old Mar 8, 2010 | 01:39 PM
northvibe's Avatar
oh yea the first time took me a while, specially figuring what size bolts and how to get this off etc. 2nd time and on i bet its super quick and easy. part that takes the longest is tightening the clamps :P
ya I dont want to bend the piping...but I did start snugging them tighter and you can feel when the clamp starts being harder to tighten... the longer couplers will help with blow off as well, but it definitely takes a little finesse.
Old Mar 8, 2010 | 01:42 PM
yeah, as soon as the bolt housing on the clamp started indenting the clamp itself (just a little bit) that's when I called it off and stopped tightening.
Old Mar 8, 2010 | 01:43 PM
jmfselu's Avatar
i havent had any issues with my injen CP, installation went smoothly and the only thing that took long was getting the angles and couplers just right...but so far so good 12000 miles later with a tune.....and looks sexy too lol
Old Mar 8, 2010 | 01:47 PM
yeah, the CIA piping had some issues with clearance ... first it was rubbing against the fuel pump rail then the fuel pump bracket. had to move them up more near the fan shroud
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
SSLOW06
Oct 1, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
