how are these numbers?
Old May 29, 2014 | 06:37 AM
Originally Posted by tuned08ss
Guess im done going wot. What bad can happen though if I may ask?
Without logging and someone watching your afr it's hard to say if you go rich/lean at wot. Def get it retuned for the intake sooner than later.
Originally Posted by SINISTER
Which intake tends to cause the least LTFT problems?
When I had a SRT4 we found the OEM intake was so good that a drop in air filter was all we needed...
Isn't there a OEM intake mod that increases the HP equivalently to a K&N intake and yet doesn't cause fuel trim issues?
Stock filter housing with zzp's intake tube, but less noise from the bpv with that.
Old May 29, 2014 | 12:27 PM
Terminator2's Avatar
No idea. I called vince and he said the vin didnt come up that he tuned it. So I figured hpt because its not gms1 or trifecta, yet it hits 22#.
Did it have Dejon intake on it when you bought it?
Old May 29, 2014 | 01:52 PM
tuned08ss's Avatar
Yes sir
Old May 29, 2014 | 02:07 PM
Yes sir
Is the car black?
Old May 29, 2014 | 04:45 PM
CudaJoe's Avatar
That LTFT is horendous lol. Thats almost CEL worthy. sounds like theres a tiny hole in your charge piping or something lol. like a tiny leak.
You sure everything is secure and there are no cracks or small small leaks? I cant imagine a tuner leaving a car like that unless 0 **** were given.
Oh and if the tune is the problem, switching the intake will accomplish nothing. That tune needs to be checked.
Old Jun 1, 2014 | 02:01 PM
tuned08ss's Avatar
Ok so I got another question. I was checking for charge pipe leaks today and decided why not install my zzp upper charge pipe. Anyway I didnt follow yhe directions correctly and ended up cutting the stock couplers too short shown in this pic.
Anyway I wanted to know if anyone know if the zzp lnf silicone replacement couplers are the part I need for the charge pipe to work now that I f'd it up.
Old Jun 1, 2014 | 02:05 PM
sam1031's Avatar
Yeah, the zzp silicon couplers are a much better fit too.
Old Jun 1, 2014 | 02:15 PM
tuned08ss's Avatar
Thanks...just ordered them. Now I have to catch the bus to work til they get here.
Old Jun 2, 2014 | 11:39 PM
SINISTER's Avatar
Changing in the intake wont help, you will need a retune no matter what intake you buy.
Hey I read in some earlier threads, a couple years back, some people said that the stock intake causes the LTFT to drift also? Was this proven to be true? Should someone consider a tune even if we just have the OEM intake? Or was this just B.S. from the past??
Old Jun 7, 2014 | 12:39 PM
tuned08ss's Avatar
Installed zzp upper charge pipe and my ltft is getting better. Must've had a boost leak. Also cleaned maf. My dejon intake filter is very dirty and I was thinking of getting a new filter anyway. Should I get the 3" one from advance auto? Term told me the dejon is 3" and the kn is 3.25". Im thinking of just getting a 3" kn filter. U guys think that would work?
Old Jun 7, 2014 | 12:59 PM
  #36
Attachment 5613
Get a AEM dryflow filter for it.
Old Jun 17, 2014 | 11:27 AM
  #37
tuned08ss's Avatar
So can a dirty filter, say one that hasnt been cleaned or changed in 60k cause the fuel trims to drift?
Old Jun 17, 2014 | 11:44 AM
  #38
You bet.
SSLOW06
Oct 1, 2015 07:21 PM
ashalle2
Sep 27, 2015 03:28 PM
metroplex
Sep 27, 2015 07:48 AM
jcarroll53
Sep 24, 2015 07:43 PM
