how tight should the bolts that hold the cames in be
Old Apr 28, 2012 | 03:01 PM
tomj77's Avatar
whats the torque specs for the cam bolts??
Old Apr 28, 2012 | 03:22 PM
tomj77's Avatar
fricken checked the torque and snapped one of the end cap bolts, thank god for the mech down the road got it out, now i need a new bolt
Old Apr 28, 2012 | 03:39 PM
SSlobalt's Avatar
Old Apr 28, 2012 | 03:55 PM
tomj77's Avatar
No biggy just need to find new bolt
Old Apr 28, 2012 | 04:01 PM
Superbalt06's Avatar
There's different specs for it. A couple have a higher spec than the others. Good thing it didn't strip the threads.
That was for lsj not sure about lnf.
Old Apr 28, 2012 | 04:05 PM
tomj77's Avatar
Wondering if I can use a normal galvanized bolt till I can get a proper one from gm
Old Apr 28, 2012 | 04:07 PM
tomj77's Avatar
I need the specs for the ones right by the cam gear. Seems 10 ft pounds but not sure
Old Apr 28, 2012 | 04:19 PM
Omiotek's Avatar
lnf is 22 ft lbs first pass and second pass is 100 degrees for the vvt motors.... the cam cap bolts are 89 inch lbs, tensioners 55 ft lbs, cam position sensors are 89 in lbs
note: the camshaft sprocket bolts should not be re used.
Old Apr 28, 2012 | 04:33 PM
tomj77's Avatar
89 inch pounds??? wow i over did it lol
ur talking the end caps right before the sproket right? those are 89 inch pounds?
Old Apr 28, 2012 | 05:04 PM
tomj77's Avatar
talking about journal cover bolt specs here. and do i just blue lock tight so they dont work loose? like my valve cover bolts did
Old Apr 28, 2012 | 05:38 PM
Omiotek's Avatar
ive never had any of that stuff back off with torque specs. the cam journals are crucial to be even... i really think you need to get a tech to help you out man.
Old Apr 28, 2012 | 06:28 PM
tomj77's Avatar
well i checked one and it was about 130 inch pounds, so i put a little blue lock tight on it and set it there, we shall see i guess, ill take it apart when i get stock bolts and see how it is.
Old Apr 28, 2012 | 06:39 PM
Omiotek's Avatar
yeah they are always over torqued. most people wrench them down
Old Apr 28, 2012 | 07:42 PM
tomj77's Avatar
well she runs. lol tick is still there seeing as i chickened out of changing tentioner, but at home it was gone, it comes and goes, maybe someone is living in there. lol ill just get a stock bolt and replace the hardware store temp one im using and ill leave it alone. the tick ill take into another dealer to look at and screw it
Old Apr 28, 2012 | 09:22 PM
Malaclypse's Avatar
You really need to reset the timing chain tensioner whenever removing the timing chain for any reason.
If you don't it could cause premature timing chain wear.
Old Apr 28, 2012 | 10:01 PM
tomj77's Avatar
no one removed the chain
Old Apr 28, 2012 | 10:23 PM
tomj77's Avatar
ordered my new bolt from create engine, learned 89 inch pounds, well i learned by screwing up, yay. lol
Old Apr 29, 2012 | 02:35 AM
Omiotek's Avatar
Yeah and there is a torque procedure aswell
Old Apr 29, 2012 | 05:05 AM
FasterIsBetter's Avatar
Yeah, and if you don't have an in-lb torque wrench you can convert it to ft-lbs by dividing by 12. I ended up having to do that cause the in-lb torque wrench I ordered from summit doesn't read out in in-lbs but rather ft-lbs....89 in-lbs would be approx. 7.4 ft-lbs
Old Apr 29, 2012 | 11:20 AM
tomj77's Avatar
i got one of those ones with a screen that attach to a normal socket. but i misunderstood how much to torque em and went made one way to tight, thats why it broke
not on those, they are just 89 inch pounds. thats all the repair manual says
there are the 10mm bolts that hold on the cam caps, they are all 89 inch pounds from what i read on the manual
Old Apr 29, 2012 | 12:21 PM
Omiotek's Avatar
its one of those things you just gotta know... its always good to go from the center and work your way out. its it a 100% neccisity? no but its good to do it. just like its also good to get them started and after then tighten up give them like a half turn so theres tension and after you have done that to them all you go back a torque them all to spec. thats just what i do
Old Apr 29, 2012 | 01:21 PM
tomj77's Avatar
i know but its only one bolt on the end lol no need for all that. just replace the bolt. but still good to know for someone who changing them i guess
Old Apr 29, 2012 | 01:49 PM
Omiotek's Avatar
yeah i figured u had them all undone. no big deal
dennis69
Oct 20, 2015 04:49 PM
Trav3480
Oct 1, 2015 08:17 PM
SSLOW06
Oct 1, 2015 07:21 PM
Tupp
Sep 30, 2015 08:18 PM
Slick_Nick
Sep 28, 2015 09:15 PM
