how unsafe is 25psi?
Old Mar 28, 2014 | 10:47 PM
dro-balt ss's Avatar
just got full bolt ons. local tuner uses hp dyno tune. what exactly is an "aggressive tune" will i be losing 3rd gear with an aggressive tune at 25psi? will gmpp clutch help with my tranny what else should i be looking at so i don't have major problems
Old Mar 28, 2014 | 10:53 PM
StevoElSupremo's Avatar
I was told that when I get mine tuned to be easy on third gear, like no mashing it at low RPM's or it'll blow up haha
Old Mar 28, 2014 | 10:55 PM
so thats how people lose 3rd… my clutch pops out if i mash it in 3rd at low rpms. i don't go wot anymore unless passed 4k
Old Mar 28, 2014 | 11:42 PM
nobody2u's Avatar
From what I understand- there isn't much point in going past 23-24 PSI on the stock turbo, it just doesn't make efficient power past that essentially.
Old Mar 29, 2014 | 12:09 AM
so what makes an aggressive tune an aggressive tune?
Old Mar 29, 2014 | 12:12 AM
nobody2u's Avatar
I'm not sure if I'm educated enough to answer- but until one of the tuners pops in to clarify I'd say the timing and the air fuel ratio are a couple key aspects. I'm sure there are other parameters as well.
Old Mar 29, 2014 | 12:24 AM
tomj77's Avatar
stay at a safe 22-23 psi on stock turbo. aggressive tune would be exactly that. doesnt always mean high psi. more timing, leaner a/f ratio. ect ect. that's about the extent of my knowledge lol
Old Mar 29, 2014 | 11:29 AM
09CobaltSS1's Avatar
Personally, I ran 25psi for basically the entire life of my stock turbo and she was still in great shape when I swapped her out for my current setup. With that said, I don't normally tune stock turbo cars over 24psi but that also doesn't mean it's "not safe" to push it to 25psi. Yes the turbo can't keep up much past 5k but there are ways to compensate for boost loss with other methods to maintain a nice flat power curve up top. What's NOT safe, it to allow for a large boost spike down low/mid range and settle down to 25psi there after. Boost ramp and a few other safety measures in the tune are key to longevity here. If you stomp the gas from 4k in 3rd gear and you see 28psi on the gauge for a 24-25psi tune, your tuner's not doing it right.
no_ss
Oct 18, 2015 11:58 PM
OPCrer
Sep 27, 2015 08:11 PM
no_ss
Sep 18, 2015 11:03 AM
blazinbaltss
Sep 7, 2008 07:45 PM
jdbunch08SS
Mar 23, 2008 11:21 PM
