hp tune/trifecta
hp tune/trifecta
Right now im running trifecta on my car and need to install a hp file. Vince told me this
What you can do is load our TF/HP layer on the car. Then you can use HP to tune the “custom” tune mode of our tune. But you have to tune it yourself – you get a stock tune from us in the layer. This option is only for people that know how to tune using HP and want to use our select-a-tune and infiniboost features with HP tuning software.
What does this all mean haha. I know i need to order the layer tune from vince then after that what would i do. I have a hp tune ready to load onto my computer i bought from MDub
What you can do is load our TF/HP layer on the car. Then you can use HP to tune the custom tune mode of our tune. But you have to tune it yourself you get a stock tune from us in the layer. This option is only for people that know how to tune using HP and want to use our select-a-tune and infiniboost features with HP tuning software.
Ahah i totally forgot about posting it here oppss....But i have a friend who knows how to work hp tunes. So IamBroke your saying load the trifecta on then do a write calibration with the mdub file over it and its good to go
Only if the tune is suitable for your mods ect. Someone with HPT still needs to log & tweak it in most likely. One tune doesn't fit all. Vince won't log & tweak a combo tune. For instance, if you bought an email tune from me I would include reviewing the log files & dialing it in as would Term & BYT.
You can not do a read entire of a combo tune either. More TF protection there.
I will be the one loading the tune on to the car and logging it and Ill make sure to adjust anything necessary. Im sure the MAF will be off a bit, and since its getting cold here I may have to pull a degree or 2 of timing, but im guessing it will mainly just need some work on the LTFT's
Yeah he asked me if I would tune his LNF and I said I havent done one before and they are different than the LSJ and other cars Ive done so he got a tune from someone I guess, so Ill just dial in the MAF and timing for him
