hp tune/trifecta
Old Oct 23, 2010 | 01:07 PM
paintballerr78's Avatar
hp tune/trifecta
Right now im running trifecta on my car and need to install a hp file. Vince told me this
What you can do is load our TF/HP layer on the car. Then you can use HP to tune the “custom” tune mode of our tune. But you have to tune it yourself – you get a stock tune from us in the layer. This option is only for people that know how to tune using HP and want to use our select-a-tune and infiniboost features with HP tuning software.
What does this all mean haha. I know i need to order the layer tune from vince then after that what would i do. I have a hp tune ready to load onto my computer i bought from MDub
Old Oct 23, 2010 | 01:10 PM
ecot3c inside's Avatar
this..
Iam Broke's Avatar
After you load the special TF base file, you do a write calibration of the M-Dub file over it, not a write entire.
Better discussed over here eh?
Old Oct 23, 2010 | 01:13 PM
Ahah i totally forgot about posting it here oppss....But i have a friend who knows how to work hp tunes. So IamBroke your saying load the trifecta on then do a write calibration with the mdub file over it and its good to go
Old Oct 23, 2010 | 01:16 PM
Iam Broke's Avatar
Only if the tune is suitable for your mods ect. Someone with HPT still needs to log & tweak it in most likely. One tune doesn't fit all. Vince won't log & tweak a combo tune. For instance, if you bought an email tune from me I would include reviewing the log files & dialing it in as would Term & BYT.
You can not do a read entire of a combo tune either. More TF protection there.
Old Oct 23, 2010 | 01:30 PM
Terminator2's Avatar
This. You need to have the tune dialed in for the car. Timing, MAF, etc need to be checked and adjusted as necessary. I normally do anywhere from 4-10 data logs depending on the mods of the car.
Old Oct 23, 2010 | 02:27 PM
InfraRedline's Avatar
I will be the one loading the tune on to the car and logging it and Ill make sure to adjust anything necessary. Im sure the MAF will be off a bit, and since its getting cold here I may have to pull a degree or 2 of timing, but im guessing it will mainly just need some work on the LTFT's
Old Oct 23, 2010 | 02:38 PM
ya well see how the car runs on hp then if its good well add the trifecta tune and do a write calibration
Old Oct 23, 2010 | 02:41 PM
So someone else is sending a him tune but you are tweaking it for him? That is strange.
Old Oct 23, 2010 | 02:50 PM
Yeah he asked me if I would tune his LNF and I said I havent done one before and they are different than the LSJ and other cars Ive done so he got a tune from someone I guess, so Ill just dial in the MAF and timing for him
Old Oct 23, 2010 | 02:52 PM
Iam Broke's Avatar
If you tune LSJ's the LNF will be cake. Just remember to keep the PE lambda around .88 on the DI engine. Too many people want to richen it up.
Old Oct 23, 2010 | 02:55 PM
Oh cool I always thought they were more difficult. His is the first LNF I have ever seen since there arent any in my town I hate ND!
