Hp tuner help!
Old Apr 30, 2013 | 08:55 PM
SilverSS_TNR's Avatar
Hp tuner help!
So I installed hardpipes, intercooler, and sri
Went to go tune cobalt with hp tuners and it says I'm locked out of the computer, now I know the previous owner had the car tuned with trifecta and claims it was returned back to stock, anyway, keep trying and trying and sending a code saying that the car wasn't returned back to the stock tune, ok so I go to one dealership and ask them to flash it back to stock, they're asking questions, why I want it, why I don't have a cat, whatever, eventually tell me they went to go do it and apparently the gm system crashed so they couldn't flash it today, but they told me that I might lock the ECU becuz I have a CEL from the catless downpipe and say I might have to purchase a new ECU @$500 nix
So my question is how true are try by telling me flashing it could lock the ECU, I've been trying to finally mod my car and run into problem after problem, anybody heard of this?!!??
Old Apr 30, 2013 | 08:57 PM
nhanson's Avatar
Sounds like it wasnt fully returned to stock
Old Apr 30, 2013 | 09:01 PM
Yea that's why I'm thinking too, just don't wanna dump 500 on a new ECU just to start finally modding the car
Old May 1, 2013 | 10:35 AM
Iam Broke's Avatar
Send the VIN to Vince at Trifecta and see if it was tuned by him or another tuner and locked. BYT was good for locking down things with different layer combo's.
A write entire will not brick the ECU if done correctly. Sorry for your pain.
What were the HPT errors? VIN/OS mismatch perhaps?
Old May 1, 2013 | 10:53 AM
Terminator2's Avatar
Yes you are correct. It needs to have the trifecta cable flash it back to stock or a Tech 2 tool but IIRC the hidden tunes cannot be fully flashed over with the Tech 2 tool so he may just want to use a trifecta cable to return it to stock.
Old May 2, 2013 | 08:17 PM
the previous owner tuned it himself..guess hes a trifecta dealer....said he flashed it back to stock but apparently didnt
anyway....went to a better dealership and talked to a master tech that knew what he was doing...said "oh u need a reflash...no problem" did it and drove away 20 min later to the tuner.....still didnt recognize it so we had to throw in a different VIN to trick the ECU....either way it got tuned last night and is running like a whole new car...im def happy with how its tuned now.
Old May 8, 2013 | 01:09 AM
Psykostevo's Avatar
A lot of the Trifecta tuned cars were not able to be read after the fact. And some of them had info on them that also made them fail validation checks after you downloaded the stock tune.
The thing that sucks if you have to buy a new ECM is that you will need to perform a clutch position sensor learn on some if them too before the ignition will turn over.
Also a blank ECM is a blank ECM. Can't connect to them with HPTuners. Make sure it's preprogrammed with a cobalt SS file on it.
Old May 8, 2013 | 01:15 AM
Vander Nars's Avatar
Another reason to not get trifecta tuned....
Old May 8, 2013 | 03:27 PM
VR09Sedan's Avatar
Nuthugger....
Old May 8, 2013 | 08:54 PM
Originally Posted by VR09Sedan
Nuthugger....
LOL I didnt ask for a pic of you but thanks.
Old May 8, 2013 | 10:00 PM
huckernage's Avatar
he did a error by not forcing the stock tune.
there is a option in ezcable.
ezflash/program/force full flash then select your files
my question is why TFT can right over hpt and not the opposite. hpt may have to do their homework.
Old May 9, 2013 | 01:11 AM
Psykostevo's Avatar
HPT expects the files to pass validation.
Vince wrote his own software and can make it do whatever he wants. This can force the tune to operate outside of the boundaries of what HPT considers a valid, uncorrupt file.
This is also a potential problem when dealing with SCT, EFI Live, HPT and other software tuning the same car.
HPT is also pretty good. I use it a lot. But I notice that it occasionally has glitches. Like I've seen someone's fuel gauge start working backwards for no reason after flashing it. Then flashed it again and it started working normal. That kind of thing doesn't happen very often, but I haven't seen it happen with my SCT software yet.
Then again on some years of late 90s mustangs I've flashed the tune with SCT only to not even have the tune actually flash. Gotta watch that crap.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
riceburner
Mid Central
Oct 5, 2015 09:18 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
09SSlow
Sep 28, 2015 12:37 AM
OPCrer
Sep 27, 2015 08:11 PM
