Hptuners not working
Old Apr 22, 2014 | 11:03 PM
paintballerr78's Avatar
When connecting hptuners to my 2010 lnf everything under scanner is greyed out. It'll connect and scan but under vcm controls everything is greyed out It's a 2009 PCM in a 2010 not sure if it matters.
Old Apr 23, 2014 | 08:40 PM
SSlobalt's Avatar
I've got an '09 PCM in my '08 with no issues.
Old Apr 24, 2014 | 08:01 AM
blueLNFftw's Avatar
How many parameters is it scanning when you run it?
Sounds like the car has a Trifecta tune on it....
Old Apr 24, 2014 | 10:19 AM
Wired's Avatar
My VCM controls are also greyed out and do not know why. I can scan and have a gms1 tune on it.
Old Apr 24, 2014 | 10:29 AM
yellowsupercharged06's Avatar
did you buy your credits ??? HPT will scan any car (no credits are needed) but once you open the VCM suite you can not do anything if you do not have credits.
Scanner and Editor are two different programs.
Old Apr 25, 2014 | 08:20 AM
Stu_x24x's Avatar
I thought 2010s were a little different setup. Meaning 2010 PCM will only work in a 2010. Something about the interface I think. Might be worth researching that a little more.
Old Apr 25, 2014 | 08:40 AM
Iirc Colodude is running an 09 PCM in his 10, so I'm not sure if that's the issue. What parameters are you scanning? (Hptuners forums has plently of pre-set configs for LNFs)
Old Apr 25, 2014 | 10:02 AM
09CobaltSS1's Avatar
It doesn't sound like there's anything wrong with your hptuners. HPT does not support any VCM controls with the e69 ecm.
Old Apr 28, 2014 | 11:23 AM
Wired's Avatar
Well there's the problem. Thanks!
I wish it did so resetting fuel trims was a push of the button.
DarrenGC
Dec 24, 2021 01:55 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Adecker
Oct 20, 2015 09:46 PM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
