Hurst STS
i had to read that a couple times. i thought you meant the hurst screwed something up. but i got mine through allecotec.com. on their website they have the b&m and hurst only listed for the ss/sc but i got one and its in my tc. im 99% the same hold true for the hurst.
The hurst works fine, a bunch of people just don't know how to install it. When you use the loctite you have to make sure you let it set for a minimum of twenty mins and you should make sure the threads on both the screw and the threads on the shifter are really clean. If you do that it will not get loose on ya.
