i wanna go lnf meth need help
Old Sep 17, 2009 | 11:52 PM
pookie025's Avatar
can some one direct me the right direction of what to do, where to buy, positives and negitives of meth
hello would really like some advice
Old Sep 18, 2009 | 01:09 AM
Projekt's Avatar
i already made a thread about this awhile ago
Old Sep 18, 2009 | 01:10 AM
ajm5036's Avatar
Obviously he doesn't know that. You should post a link for him.
Old Sep 18, 2009 | 01:17 AM
Projekt's Avatar
thats way to much work at this time
Old Sep 18, 2009 | 07:36 AM
hiltu's Avatar
I am running water/meth on my 2008 SS. I recommend Devils Own, they have a new kit called the DVC-30. It has an internal map sensor so you just gotta tap into a boost source. Its a progressive controller, mine starts injecting at 12PSI and tops out at 25PSI. I went with the smallest tank and mounted it on the passenger side under the hood. The pump is located below the passenger headlight just a couple inches from where the foglight sits. My nozzle is located on the bend going out of the coldside piping. Bald Turbo Freak did all the tuning. I have HP tuners, so i can send my file if you/your tuner would like to look at it. After all the tuning was done i made 338WHP and 346WTQ. I had some compressor surge issue along with stock boost controller "hick-ups". Anyways if you need pics just PM me and tell me what you would like to see.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 27, 2015 08:53 PM
