I'm thinking I should start a build thread. Guess this is it.
Old 03-20-2019, 09:24 AM
  #851
steelmesh's Avatar
Originally Posted by tomj77
prometh.com. they do awesome work and have alot of stuff places like devils own dont. And they actually care. The guy will straight up phone you and discuss your setup and exactly what your looking for and make it from there. They dont use metal line ends so no rusting, and they communicate till you are satisfied. Check em out.
Devils Own owns your wallet if you buy their "Brew", I tested it to be 8% methanol content after I found it slushing in cold weather.
Reference this thread https://www.cobaltss.net/forums/adva...46/index2.html, I was supposed to upload this video over last Christmas but got sidetracked because I purchased materials with different densities to invent a no-nonsense way to measure methanol content quickly, where the different materials will float or sink, that's the idea anyway.
Old 03-20-2019, 09:32 AM
  #852
steelmesh's Avatar
A little catch can system update. Well its done but I still gotta do some testing under boost. I installed a boost gauge to crank case via the port on my old oil sperator dipstick oil drain back, and at idle instead of getting positive pressure I now get -1 vac. It holds stead and does not fluctuate. So solved that issue.
Are you using the factory PCV setup, I am just wondering how you can maintain crankcase vacuum. Or is this just at idle? My LE5 build has major blowby, haven't determined if that was the builders fault though (ehem). I custom built a large can, it catches excessive amounts of crap (I removed the factory baffling though), so I had to add a pre-baffle to help drain the crap back into the engine to be cooked again. I also welded a 5/8" barb to the valve cover in addition to using the factory port.
More pictures here: Twincharged Solstice = Turbocharger + Supercharger
Old 03-20-2019, 09:45 AM
  #853
tomj77's Avatar
nope. I made a custom 2 can setup with external pcv valve . works like stock but is external and routed though catch can. It should be in previous pages of the thread. I have yet to twst under driving and boost. Next month when i register car for summer
Old 03-20-2019, 08:43 PM
  #854
tomj77's Avatar
Here it is on the car, intake mani is a little busy lol. line goes to the bracket with the solenoid, then down to flow meter, then filter and main line.
Old 03-20-2019, 09:11 PM
  #855
63 Nova SS's Avatar
That's a sweet setup
Old 03-21-2019, 07:34 AM
  #856
tomj77's Avatar
im a little scared 250psi will break the filter to flow sensor since they are plastic and it hits at 90 degrees. Gonna test it, i may need to support em.
Im also gonna try a set of one step colder plugs, iv been having random knock up top and its on and off depending on temps. See how she does. Different set then i tried on stock turbo. The right ones this time. Lol
Old 03-21-2019, 11:31 AM
  #857
jdbaugh1's Avatar
I run an AEM steel mesh filter on the intake side of the pump. Is that filter/housing you are using rated for pressure?
Old 03-21-2019, 01:22 PM
  #858
tomj77's Avatar
i dont even know lol ill check. My tank fitting has a screen
Old 03-21-2019, 01:25 PM
  #859
tomj77's Avatar
**** ya it is. Lol gonna have to change that i guess.
Old 03-21-2019, 01:45 PM
  #860
jdbaugh1's Avatar
Lol it was rated pretty low I take it?
Old 03-21-2019, 03:11 PM
  #861
tomj77's Avatar
it just said meant to go between tank and pump. 😂 this is actually good, i was a little worried it might break off lol
Old 03-21-2019, 03:24 PM
  #862
jdbaugh1's Avatar
That's the way mine is to. I'm assuming yours is from prometh though? Is it stainless steel mesh or what is the filter medium?
Old 03-21-2019, 08:09 PM
  #863
tomj77's Avatar
stainless mesh
Old 03-21-2019, 08:11 PM
  #864
tomj77's Avatar
Well i fixed it, dont know why it wont upload on my phone. Now i need another fitting to install the filter on the tank lol. Oh well.
Old 03-21-2019, 09:48 PM
  #865
steelmesh's Avatar
The tank filter should be mandatory, but for the people who can't handle it at least all nozzles/jets have built in steel mesh screens. I recently changed out a jet with my Snow kit, there was some jelling funk starting to build up, so I recommend inspecting the jet filters more often than not, maybe even catch your pump starting to fail if it is disintegrating (if that is the failure mode).
Old 03-22-2019, 12:41 AM
  #866
slapbetcommissioner's Avatar
That’s a pretty legit meth setup Tom. You must be pushing for some big numbers if your going through all of that. Should solve fueling issues.
Old 03-22-2019, 09:36 AM
  #867
tomj77's Avatar
472 on the **** dyno at speed factor. First they heat soak it with no fans then when you finally dont spin on the dyno and they use a fan its too late and ur pulling timing cause of intake temps lol . but ya getting it ready for e30 and 500 plus
Old 03-23-2019, 10:22 PM
  #868
tomj77's Avatar
well she is ready to go.
little issue iv been having for a few years. at idle it will idle and then stumble once in a while and a/f will go lean a bit and trims as well. what you guys think? time to replace that 10 year old fuel pump in the tank or something else?
Old 03-24-2019, 08:50 AM
  #869
steelmesh's Avatar
What is STFT/LTFT doing? Might try raising idle RPM to see if that helps
Old 03-24-2019, 01:14 PM
  #870
tomj77's Avatar
Ltft is fine. Stft hangs around 0 plus or minus. Then every 15 seconds or so it will half second stumble and trims will goto about 6.then back down. A/f goes to 16.5 to 17 then backback down to 14to 15.
  #871
tomj77's Avatar
Ill post a video later
Old 03-24-2019, 03:22 PM
  #872
Log idle while turning on and off your rear defroster
Old 03-24-2019, 05:31 PM
  #873
tomj77's Avatar
what you thinking?
Old 03-24-2019, 10:09 PM
  #874
what you thinking?
If its spaced out it could be the additional load from the alternator engagement. I chased a similar event for a bit and then read a comment from cobaltssoverboosting about idle tuning and the need to log various loads (headlights, fog lights, stereo, defroster, AC, windows)
Old 03-25-2019, 06:52 AM
  #875
jdbaugh1's Avatar
I used to have problems with idle quality of Trifecta tune. Many times it would idle better with AC compressor on. But I would have the same problem (though I know ECU's way different.) It would be sitting there idling fine then all the sudden it was like a flip of a switch and it would go lean (iirc) and stumble around and then recover into a rev-fest where the rpms would rev up and down. It was very annoying and embarrassing at stop lights.
Quick Reply: I'm thinking I should start a build thread. Guess this is it.
