Images/Video from today's "Stage 2 SC vs. SS/T" dyno face off (56k, think again!)
Synapse Motorsports (where we tested), is a few miles away from Schenectady County airport, which has a surveyed elevation of 378ft.
Maybe, maybe not. I don't know.
But as I had stated before, my intent was to compare a Stage 2 SC to an SS/T on the same dyno, on the same day, at virtually the same time.
I was not trying to compare our dyno numbers to what anyone else around the country had gotten.
And I think I succeeded!
Thanks!
I think it was as fair a test as you could do between 2 cars (dynoing them together).
Don't you think?
Thanks!
Don't you think?
Last edited by firemanfrank; Jun 20, 2008 at 12:51 AM. Reason: Automerged Doublepost
Yeah no one can argue about the numbers, these were good conditions, and great numbers for both, hopefully we can stop all the fitting. But thanks for taking time out of your day to figure all of this out.
OMG!
The first thread I ever started that became a "sticky".
Utter Coolness!
No problemo.
I was as interested as anyone else here as to how much whp/trq the two cars would make when they were dynoed together.
P.S. A small sidenote regarding a quote from the manufacturers of Dynapack dynos:
"Dynapack attaches directly to the axle(s), thereby overcoming all the disadvantages of tyre distortion including noise, torque steer, loss of traction, tyre heat and design variations in the tyre."
Utter Coolness!
Last edited by firemanfrank; Jun 20, 2008 at 10:09 AM. Reason: Automerged Doublepost
Well, they've learned here too...the TC does not have the 'wheel-hop-perpetuating-marshmalllow-mounts' that SC suffered from. Additionally, upgrades to the transaxle's internals have occurred.
Heh, as to be expected from an outfit selling such equipment. They fail to mention that these factors are also part of the car's overall behavior, and thus provide a more realistic depiction of the car's capabilities when it's on the only surface that really matters...the road or the track.
The inertial load alone of one's rolling stock (wheels/tires) is a significant aspect of the car's 'to the road' performance. Mind you, I'm not dissing the testing you guys did...I think it's cool and a very uniform session. Just addressing some of the unique aspects of this style of portable equipment.
"Dynapack™ attaches directly to the axle(s), thereby overcoming all the disadvantages of tyre distortion including noise, torque steer, loss of traction, tyre heat and design variations in the tyre."
Last edited by Hahn RaceCraft; Jun 20, 2008 at 01:38 AM. Reason: Automerged Doublepost
I'm no absolute expert on dyno types, I was just looking for a nearby dyno for the test.
And when Synapse reported they had an SS/T (and being they were only 20 min. from my home) it was a perfect place to go.
I'd love to see other people do a same day Stock or Stage 2 SC vs. SS/T test done on other dynos as well!
The only disadvantage about dynapack that I have ever seen is the setup time to get a car mounted on. Other then that I fail to see why having the wheels and tires on or off matters. Are you just suggesting that the numbers the dyno puts out are not as accurate as they could be, or that not having the weight and characteristic of the wheel/tire will affect tuning accuracy?
im just not sure what you are trying to get at with this comment, especially with such inaccurate information.
And just for fun, I found this Youtube video where a dyno shop that had a Dynapack tested a car on their dyno and on a Dynojet Dyno on the same day (just a few hours apart): http://www.youtube.com/watch?v=UZXbk3o-xHg
The car tested ran in 2 different modes, Low Boost and Medium Boost.
RESULTS:
Low Boost
Dynapack - 219whp/160tq
Dynojet - 245whp/183tq
Medium Boost
Dynapack - 303whp/197tq
Dynojet - 332whp/217tq
They found that the Dynojet generated between 8-10% higher numbers than a Dynapack at the 200-350whp level. Applying their results to the test that we did at Synapse (using the lower 8% correction factor), this would translate into:
Stage 2 SC - 254whp
SS/T - 265whp
I'm thinking that maybe the Dynapack might be closer to true whp numbers than a Dynojet ...
Won't make any difference tuning the car no. Loading the engine you are still hitting the same map cells with or without wheels and tires. On a inertia dyno such as dynojet it indeed does make a difference. You can make more power by raising the air pressure way up. I am not saying negative about dynojet brand or any other for that matter. Just trying to clear up some confusion about dynapack and how they work. Seems to be lots of questions and misunderstandings on them. A skilled dyno operater/tuner can have great results on either.
power
