Images/Video from today's "Stage 2 SC vs. SS/T" dyno face off (56k, think again!)
#101
#103
Your getting the idea of the "claim" wrong.
The "claim" made by GM is that the SS/T makes 260hp at the crank.
On Synapse's dyno, it made 237 hp at the wheels.
If you add in the 20-25 hp drive train loss that another Dynapack owner had tested to be true, then the 237whp of the SS/T figures out to 257-262 hp at the crank.
Exactly what GM said it made ...
#104
#105
... im speechless. I suppose you think that the stg 2 s/c puts down 250hp to the wheels (even now with the dyno?)
And I might point out the T/C appears to be underrated in the torque department.. 258 lb-ft of torque at the WHEELS.....
#106
"227whp/203tq Dynapack Dyno=252whp/228tq So YES I DO or does only the t/c get the extra 25.Now I am really getting confused I know I have seen on here many time people saying the 205 hp of the ss s/c was at the wheel. So did GM change the way they advertise their hp ? Or was the s/c auctually 180hp ? If thats the case then holy **** you gained 72 hp from just a stage 2 kit .
#107
"227whp/203tq Dynapack Dyno=252whp/228tq So yes I do or does only the t/c get the extra 25.Now I am really getting confused I know I have seen on here many time people saying the 205 hp of the ss s/c was at the wheel. So did GM change the way they advertise their hp ? Or was the s/c auctually 180hp ? If thats the case them holy **** you gained 72 hp from just a stage 2 kit .
#108
yeah I know all dynos are different so just look at the numbers for the ones here the gm stage 2 did still put down over 250. and I think saying you can get over 70 more hp at the wheel with a GM stage 2 and no other mods is high
MODS: *too many to list...and still not fast*
lol yup I know what you mean
#109
There's already been "same dyno testing" of before/after Stage 2. I've linked to this post at least half a dozen times already, but here it is again.
**remember, the actual numbers aren't what's important - it's the difference in the numbers that counts**
Modified Mag dyno test results for GM Stage 2 Kit on SS/SC + results for K&N Typhoon
https://www.cobaltss.net/forums/show...highlight=dyno
The March 2007 edition of Modified Mag has the before/after test results for installing the GM Stage 2 kit on a stock SS/SC.
Without the Stage 2 kit, the car dyno'ed at 199.6 WHP and 177.3 ft/lbs torque
With the kit, the car dyno'ed at 223.8 WHP and 207 TQ
So, plus 24.2 WHP, plus 29.7 TQ with the Stage 2 kit.
The kit demands premium fuel from that point forward, of course. There is a big improvement in the midrange of the hp/tq curves, where a lot of spirited driving occurs.
They then added to the system the K&N Typhoon Air Intake System to the car.
This added 11.4 WHP and 1.6 TQ at the high end of the curve. Results were much less in the midrange of the hp/tq curves...very slight improvement in the 3500 to 5000 rpm range. And that was after the stage 2 kit installed....
So there you go, 223.8 WHP and 207 TQ with Stage 2 (+24.2 WHP, +29.7 TQ).
BTW, whp/trq #'s are almost EXACTLY what I got.
#110
I am not comparing anything but the numbers you posted and I dont see where you think I am.
There was one ******* who said
"... im speechless. I suppose you think that the stg 2 s/c puts down 250hp to the wheels (even now with the dyno?)
I said
"yes I do--->BRN169 - 2007 Sport Red Cobalt SS Supercharged <262whp/224ft lbs> on a mustang dyno I was there and this is what he put down.His numbers are in the dyno thread"
<I am not compaing it to the dyno you used just saying what it put down on the dyno he was on.
Stage 2 - 227whp/203tq Dynapack Dyno(not being compared to any other dyno so STOP and read again if you think I am.)
(Stock 08 SS made 237whp/258tq on **SAME DYNO/SAME DAY**)
so if the t/c made 257-260 at the crank then the stage 2 did make only about 10 less at the crank ,correct? Adding the numbers you added to the t/c to the s/c is what about 247-250?
some people are looking at you putting up the t/c number with the added 20-25 hp (257)and putting it against the 227 you saying for the s/c and seeing a much bigger diff then there really is
I have said noting bad about the t/c. I for one like to see each genaration of car made better . Hell I wish the t/c pu out 305 like the Si .I cant wait to see what they will start putting out when mods become available.
But for thoses that think their t/c will walk all over a stage 2,you are sadly mistaken it would be a drivers race not a hp race.
and damn thoses t/c tq numbers are insane for a fwd car.But since the time attack cars specs were Engine: ECOTEC LSJ Supercharged with larger injectors and 77.9 mm pulley
Engine displacement (cu. in / cc): 2000 cc
Horsepower maximum (hp / kw): 236 hp
Torque maximum (lbs-ft / Nm): 270 lb-ft
Transmission: F35 5 spd mt with 4.45 final drive
high tq is nothing new to these cars
#111
(more on what my car would have put down on a Dynojet at end of thread)
... the stage 2 did make only about 10 less at the crank ,correct? Adding the numbers you added to the t/c to the s/c is what about 247-250?
Ok, now for what my Stage 2 would have made on a Dynojet ...
I recently posted a link where a Dynapack shop had a Youtube video showing how they tested a car on their dyno, and then on the same day on a Dynojet:
"Dynapack and DynoJet head to head comparison"
http://www.youtube.com/watch?v=UZXbk3o-xHg
In their back-to-back testing, they reported a 10% loss on the Dynapack vs. the Dynojet.
That being said, my 227whp/203tq on the Dynapack would have been the equivalent of 252whp/226tq on a Dynojet.
Very interesting!
#112
Very interesting!
Very interesting!
That would place the SS/T at #13 on the list of 49 results on this forum's "OFFICIAL Dyno Thread (take two)".
My Stage 2 SC would be at the #24 spot!
#113
#114
Si? Honda civic Si? That doesnt make sense since the 08 civic Si is 197 horsepower at 7800 rpm and 139 lb.-ft. of torque at 6100 rpm. What car are you referring to?
I agree about the aftermarket - I cant wait to see what these cars are capable of - for all we know they are about maxed out for reliability right now . I am really concerned with how well the transmission will hold more power, since we are at its max now, and it looking at the graphs, it seems as though GM intentionally tuned the power back.
BTW I am going to a Dynojet dyno later this week. Ill open a new thread with the results, since it wouldn't be valid comparing it here. I still havent found anyone in the Raleigh/Durham area with a Stage 2 that would be willing to dyno with me (I'D EVEN PAY!)
#115
Seriously, Stage 2 SC peeps that live near I/I/F ...
Take him up on his freakin offer already!
#116
here you go
http://www.tuninglinx.com/html/cobal...charged-2.html
#120
good job synapse and firemanfrank on all that work done.
it means alot since i dont think i can get anything dynoed where i live.
keep it up guys.
i wan to get the catback system form gm. do you guys think its worth it. any gains?
keep it up guys.
#121
Hey, I sent you a PM, but i'm definately down for a comparison. If you don't already have a shop picked out, there is Phantasm off Capital Blvd, or RPM down in Raleigh.
#122
Nice video. I noticed the nearly $500 Snap-On Impact wrench. I got one out in the shop. I LOVE IT.
Dynopack don't have to worry about the car taking off due to poor strapping.
#123
haha you got that right, its definately a must have around the shop. a lot of money but definately worth every penny. we use them so much we got two now.
#124
Speaking of which I need to call them and find a settlement. Being unemployed SUCKS. I'm losing everything. But I'm going to start on a fresh clean slate when I leave for basic training.
#125
The only disadvantage about dynapack that I have ever seen is the setup time to get a car mounted on. Other then that I fail to see why having the wheels and tires on or off matters. Are you just suggesting that the numbers the dyno puts out are not as accurate as they could be, or that not having the weight and characteristic of the wheel/tire will affect tuning accuracy?
It works, it's just missing this detail of actual on-road results, which is what we typically rely on a chassis dyno to show.
the dynapack is the most expensive dynamometer on the market, at more than double the price of a comparable dynojet. so im not sure what you mean by an inexpensive alternative to a "real" chassis dyno.
im just not sure what you are trying to get at with this comment, especially with such inaccurate information.
Expense also goes to installation, which is a key component of the overall cost, and this lower cost (read: Less Expensive) is touted by Dynapack's own website as a 'selling point':
Our cost: Purchase price or lease payment
Our competitors cost:
- Purchase price or lease payment
- Additional components
- Computer
- Installation costs
- Training costs
- Insurance
- Electricity
- Lost shop space
So, no offense intended....Dynapack has its fans. I just offered an explanation to a question asked.
Last edited by Hahn RaceCraft; 06-26-2008 at 02:12 PM. Reason: Automerged Doublepost
