injectors & sparkplugs question
Old Jan 11, 2010 | 12:44 PM
cardelino18's Avatar
ok so im going bug turbo...the car is on the shop right now making a custom turbo kit... my question is do i need to change the injectors and the sparkplugs?
if so which ones do you recommend and what size?
Thanks!
Old Jan 11, 2010 | 12:46 PM
BYT*SS*TURBO's Avatar
injectors no, plugs yes. I hope whatever shop is doing this for you has the ability to raise the DI Fuel Pressure for a bigger turbo.
Old Jan 11, 2010 | 12:48 PM
im tuning it with vince @ trifecta
Old Jan 11, 2010 | 12:53 PM
Sweetsandman's Avatar
Really? And youre a senior member? No aftermarket injectors are available and the stock ones can handle more power than youll make anyways. The stock spark plugs might be good...maybe one step colder...but some people have had misfire issues with them...id recommend it though
Old Jan 11, 2010 | 12:59 PM
thanks for the info....
but wats does me being a senior member has to do with my question?
Old Jan 11, 2010 | 01:05 PM
Just assumed that perhaps you had been around the section dealing with your motor and platform long enough to know that because there have already been 100 threads on the topic...guess I shouldnt ASSume.
Old Jan 11, 2010 | 01:31 PM
ecotecturbo's Avatar
You should know by now that there are no aftermarket fuel injectors available for the LNF.
Old Jan 12, 2010 | 12:06 PM
well i did know that it was pointless changing them the car has stock turbo... but havent ready anything about if it would be better with a bigger turbo...
Old Jan 12, 2010 | 12:13 PM
Prolly 1 range colder would be fine with a .030-.032 gap. As stated, no injectors for the LNF. ZZP pushed the car to 540whp (IIRC) on the stock injectors with just the DI FP raised.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
