installing aftermarket gauges
Old Jan 18, 2009 | 08:56 PM
tomj77's Avatar
im gonna be installing some aftermarket gauges and i was wondering if i can piggy from the ignition/ground from the stock boost gauge wires in the ss/tc
Old Jan 18, 2009 | 09:17 PM
HunterKiller89's Avatar
yes....but how many gauges will be added? Im sure too many gauges on one power source can't be good.
Old Jan 18, 2009 | 09:19 PM
SUKXOST's Avatar
PLEASE do a how to with pics man. Have not seen one. I have mine but they did it wrong and I'm sending it back to get re-done. I know it's fairly easy but a PITA to get all the trim off and such. I'm sure a few of us would appreciate it man!
Where'd you get your gauges from ?
Thanks
Old Jan 18, 2009 | 09:24 PM
Mazdaboi318's Avatar
I want to get some prosport tinted gauges! what is everyone else doing? and i wouldnt know how to hook them up haha
Old Jan 18, 2009 | 09:27 PM
kling1022's Avatar
i just want to get a simple A/F gauge. I just want a double pod on my car. nothing too fancy. The A/F gauge is easy. You just have to splice into the purple wire in your wiring harness
Old Jan 18, 2009 | 09:29 PM
What guages do we exactly need? i was thinking getting the A/F. and a different boost guage. but i want to keep my guages on my pillar
Old Jan 18, 2009 | 09:30 PM
Maven's Avatar
the pink wire is the power wire, it uses the 15a WIPER fuse.
Old Jan 18, 2009 | 09:32 PM
EatonTVS07's Avatar
EGT, boost, and wideband
Old Jan 18, 2009 | 09:34 PM
i guess ill be needing a three guage pillar...
Old Jan 18, 2009 | 10:47 PM
you shouldn't be buying gauges if you dont know why you need them. The A Pillar come off with a screw underneath the little part that says AIRBAG. It's not the airbag, it's just a cover for the screw. remove that and the A pillar comes right off. as Maven said, the pink/red wire is the power wire. Splice into that and you're good. SUKXOST, I can't recall where i bought my gauges. I clicked on the link provided by autometer.com to list their vendors and bought from one of them.
Old Jan 18, 2009 | 10:51 PM
kling1022's Avatar
does anyone sell the beige or tan looking pillars for our cars? Like double and triple pod pillars
Old Jan 18, 2009 | 11:18 PM
cobaltssoverbooster's Avatar
you can piggy but too many will cause the fuse to blow i reccomend getting just the boost and afr gauge since hpt has a catalyst exhaust temperature already in it if you plan on using them. otherwise yea your good.
no tan pillars that i have seen, must paint them i will have this same problem too.
Old Jan 18, 2009 | 11:35 PM
08BlackSS/TC's Avatar
Cobalt Addiction has them
Old Jan 18, 2009 | 11:41 PM
kling1022's Avatar
umm no dice. It is saying coming soon and has said that for like 2 or 3 months
Old Jan 18, 2009 | 11:53 PM
u need to talk to CA on the forums to get them i believe
Old Jan 18, 2009 | 11:54 PM
BartSS's Avatar
I'm getting the air to fuel and oil pressure gauge in mine. As well at the stock boost gauge
Old Jan 19, 2009 | 12:01 AM
tomj77's Avatar
i had six on the same lighting fuse and ignition on my talon with no problems. im only putting a water temp and oil pressure on my ss besides the boost. so that shouldnt be a problem. and yes i know i got water temp in the display thing whatever its called. but i want a guage i can see. and im not spending the money for the wideband and such canse i dont need em im not modding my car much just basic stuff. my talon was amoney pit, im not gonna spend everything i have on modding anymore. lol
But ya it shoudnt be to hard to find what wires u need from the boost gauge, get a volt meter and unplug the boost gauge, stick the prob into the the plug ports and see where u constant is when ignision is on, and what one comes on when u turn on lights, and black is usually black so thats all ull need .
go here http://cobalt-addiction.com/products/pages/gauges.html
it's in Performance>Gauges
Old Jan 19, 2009 | 12:17 AM
kling1022's Avatar
thanks man.
Old Jan 19, 2009 | 12:24 AM
stoon_cobalt_colby's Avatar
yup i just installed mine today didnt fit quiet right had to mod it a little bit but looks good
thanks man.
No prob dude, anytime!
Old Jan 19, 2009 | 12:27 AM
sheldon729's Avatar
While on topic of gauges has anyone thought of installing a wide-band air/fuel ration gauge to tap into the stock wide band on ours cars so whe can monitor the parameters? The first 02 sensor on our TC's are a lambda wide-band A/F ratio sensor
Old Jan 19, 2009 | 12:29 PM
Get an Interceptor gauge and you won't need to tap into anything
Old Jan 19, 2009 | 01:13 PM
Maven's Avatar
A: I wouldnt recommend just "tapping in" the factory HO2S1, just asking for problems.
2: If you wanna get truly technical, sensor 1 on the LNF isnt a wide-band. Its a narrow band with a pumping cell. Calling it a wideband is a surefire way to **** of an engineer.
True wideband sensors go for around $1000.
Old Jan 19, 2009 | 06:05 PM
tomj77's Avatar
we're not engineers so its a wideband. lol
