ISO LNF ignition coil wiring diagram
Old Mar 11, 2020 | 01:48 PM
cobaltssdude420's Avatar
Does anybody have access to an LNF ignition coil wiring diagram/pin out? There isn't one in my Haynes manual and I'm finding everything BUT LNF on google...
Old Mar 11, 2020 | 06:21 PM
zeeky420's Avatar
What are you trying to do
Old Mar 11, 2020 | 08:08 PM
Pretty sure all coils are wired the same across 08+
Old Mar 12, 2020 | 04:45 PM
Kolt's Avatar
They are basically wired the same but different pinouts due to different pcm setup.
LNF ECM x1 connector end view.pdf
LNF ign coil 1 end view.pdf
Old Mar 12, 2020 | 04:59 PM
Kolt's Avatar
Here is the rest
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 12, 2020 | 11:17 PM
Originally Posted by Kolt
Here is the rest
Thanks for that Kolt but I already had it figured out. Turns out all the coils are connected to each other and then another single wire is spliced into them that runs to the fuse box. I followed them all the way to the fuse box haha. Gave me an excuse to clean up my engine bay
Old Mar 12, 2020 | 11:20 PM
Was doing a "kind of" wire tuck lmao. I cut into the wires that run to coils 1 and 4 and there were 2 PK/BLK wires. I got all paranoid and thought I'd fry the pcm if I didn't figure out where they go so I followed them back to the fuse box. 10 hours later I have a nice clean harness that's semi tucked ?
cw383
Nov 19, 2017 07:34 PM
User 60923
May 14, 2016 09:25 AM
user 72239
Wheels and Tires
Jun 7, 2014 06:33 PM
silverbullet08
Aug 2, 2011 07:37 PM
Black_Turbo_SS
Apr 12, 2010 12:02 PM
