Just got dyno'd and the numbers seem low
Old Oct 15, 2010 | 12:31 PM
RiceCop's Avatar
Originally Posted by tom.g
Lol I ran on a Mustang Dyno a couple months ago exact same HP as you 269.3 but my Torque is at 320.4 (also on a mild 22PSi Trifecta Tune)
But what did you make before the tune? I picked up over 50wtq from before to after.
Old Oct 15, 2010 | 12:46 PM
Cobalt_Daddy's Avatar
Originally Posted by superbrowndude
did you dyno the car during an earthquake? lol
Old Oct 15, 2010 | 03:13 PM
tom.g's Avatar
I went from 241WHP/262WTQ to 269WHP/320WTQ I'll try to get a dyno graph up later on some time.
Old Oct 15, 2010 | 03:31 PM
RiceCop's Avatar
We are actually really close as far as what we picked up..
You gained 28whp, I gained 39whp
You gained 58wtq, I gained 56wtq
Old Oct 15, 2010 | 06:10 PM
tom.g's Avatar
I just think it's strange how our Tuned HP can be the same and our Tuned TQ can be so off
Unless you have a more agressive tune with a more conservative dyno?
Old Oct 15, 2010 | 08:43 PM
RiceCop's Avatar
Could be the K&N SRI that I have? idk, but I agree with you lol. I noticed when I did another members car on the same dyno that his HP/TQ spiked pretty quickly while mine came in later but was higher over all. The only difference in the cars was stock intake on his vs my k&n sri.
Old Oct 16, 2010 | 12:42 PM
1SLOLT1's Avatar
I put down. 300 whp and 335 wtq with catless down pipe and GMS1 tune
Old Oct 16, 2010 | 05:30 PM
RiceCop's Avatar
They dyno that I work with is VERY conservative. I know it's not just my car as I've tuned 4 LNF cars on it now and they've all made similar numbers (more or less depending on mods)
Old Oct 18, 2010 | 12:15 PM
Kegger's Avatar
I'm also still seeing the same thing that I thought was corrected in my second tune. When my car hits full boost at 23 psi, it immediately falls back down to 20 psi, then climbs back up to 23. I'm guessing that why my torque curve peaks at around 3k rpm, then drops slightly, then peaks again at about 4k rpm.
I'm wondering if my ECU is telling the wastegate to open? This happens every time I go WOT.
Old Oct 18, 2010 | 12:21 PM
tom.g's Avatar
That makes sense actually. And I thought the dyno I was on was stingy, the one your on is a selfish bitch
Old Oct 18, 2010 | 12:25 PM
  #36
BYT*SS*TURBO's Avatar
Tune issue if the boost is doing that.
Old Oct 18, 2010 | 12:49 PM
  #37
Kegger's Avatar
I sent Vince a few datalog files and he said he doesn't see it. I mailed back the cable to him today so I guess I'm just screwed then. Plus the fact that he said he could have the stock tune at a safe 20 psi for when I road race never happened either. I'm only getting 15 psi on my stock tune and the car drives worse now than when it was stock. I kept asking him about that and he never addressed the issue. I must say I'm not at all happy with this Trifecta experience and results.
Old Oct 18, 2010 | 12:52 PM
  #38
You must have a leak or something. I would check and clean the BPV, then just do a general once over on the car. The boost should not toggle like that with a TF tune.
Old Oct 20, 2010 | 12:42 PM
  #39
Kegger's Avatar
No boost leak that I can find. I'll try to look at the BPV this weekend. Maybe my spring is to loose and I need a stronger one?
Jan 12, 2016 12:01 AM
maliki778
Oct 1, 2015 07:39 PM
SSLOW06
Oct 1, 2015 07:21 PM
Slick_Nick
Sep 28, 2015 09:15 PM
metroplex
Sep 27, 2015 07:48 AM
