Just Picked Up My Cobalt SS/TC!
To the OP downpipe is the most beneficial mod you can do on these cars. Intake is worth while as well if you're sure to tune for it. Intercooler, Charge Piing, and Cat-Back are more of an option then anything.
If you want the BOV sound go with the Forge BPV modern performance sells it. It's a much cheaper solution opposed to paying for a BOV, Charge Piping with the MAF relocation to mount the BOV, and relocate the MAF, and a tune to be able to relocated the MAF.
Suspension wise Pedders, and SSC aka CM seem to be the popular choices concerning springs.
How do you figure? I put it on within 6 hours of owning he car.. no problems what so ever.. no CEL no idle problems.. The k&n is fine. It's the other brands you need to worry about.. just be sure to disconnect the battery for 10 minutes to reset the ecu.
hey guys thanks for the ideas for mods i was thinking about the dejon intake and charge piping anyone have those? oh and here are some pics
http://i1232.photobucket.com/albums/...vilela/044.jpg
http://i1232.photobucket.com/albums/...vilela/047.jpg
http://i1232.photobucket.com/albums/...vilela/038.jpg
http://i1232.photobucket.com/albums/...vilela/019.jpg
http://i1232.photobucket.com/albums/...vilela/026.jpg
http://i1232.photobucket.com/albums/...vilela/035.jpg
Get yourself the K&N SRI over the Dejon
I prefer the ZZP Upper CP as it bolts to the engine, i had HAHN ones dent my hood from hopping around
ZZP or any Catless Downpipe best mod for the Money
You can save a ton of money by getting your own Stage 1 sensors and getting a custom tune
D-Mac is right any Catless Downpipe is the best mod for the money, and one can be had from Bad-Mab even for $160.00 shipped. ZZP, and Modern Performance also offer Catless Downpipes for a very affordable price, and the fact that the K&N Intake is a better choice compared to Dejon. Unlike the K&N SRI the Dejon doesn't have a mounting solution and are prone to rubbing on the AC line located underneath the intake.
IIRC NY uses a code scanner instead of an 02 sensor, so you should be fine as long as they don't do a visual inspection, or you don't have a cel. Someone from NY can confirm this please?
Doesn't matter which intake you install the car shouldn't get a CEL or have an idle problem. It is true the K&N has shown more promise then the other intakes on the market, but that does not make it exempt from the problems observed with throwing on any other intake. Wow you can hear your turbo congratulations, and any intake including the K&N will skew your fuel trims unless you tune it for the intake. so please tell me is it important to have fuel trims that are adjusted properly?
All in all, it's not a big deal that you're throwing a CEL for an intake for LTFT's or STFT as long as it's within reason. Either way, a tune can help adjust fuel trims back to tolerance.
you know, just because you throw a CEL doesn't make it dangerous. Most CEL's are emissions related. The ones that you should worry about are misfires. And concerning LTFT's and STFT's, ideally you want them to be at 0, but it's not particularly bad if they go rich/lean by 1 or 3 increments.
