K&N intake fitment
Old Oct 10, 2011 | 01:46 PM
Wangspeed's Avatar
K&N intake fitment
Less than impressed by the K&N intake. A bunch of non-stainless hardware, and the MAF, of all damn things, will likely hit or touch the rubber under hard acceleration or braking. The vibration from that will likely throw off the MAF reading. I've tried adjusting the shield and intake a variety of different ways, and none were great. I may take a Dremel to it at some point.
Why's it so damn hard to make a decent aftermarket part...
Old Oct 10, 2011 | 01:48 PM
ford's Avatar
Not really an issue, you can rotate it a little more out of the way. Also, i would assume sagging motor mounts could have an impact as well.
Old Oct 11, 2011 | 12:16 AM
CrystalRedSS's Avatar
i dont think mine's like that
Old Oct 11, 2011 | 06:36 AM
Wangspeed's Avatar
I've got stage 1 mounts. I forgot that might affect this placement.
Old Oct 11, 2011 | 06:39 AM
CudaJoe's Avatar
Dont worry, mines the same way. I tried a multitude of different ways of mounting it and I cant get it to move away from that heat shield. Only option is to trim the heat shield but no one should have to worry about that...
Mine doesnt hit though so you maybe in the clear.
Old Oct 11, 2011 | 11:57 AM
ford's Avatar
With the addition of my stage 2 mounts mine comes pretty close to touching. I have 4k on it and not a single issue. So long as you arent getting a ton of pressure against it, the MAF should be fine. From the picture you provided it doesnt seem that you have any pressure at all on the MAF and there is still the fluff of the rubber surround before it would make contact.
Old Oct 11, 2011 | 12:01 PM
Wangspeed's Avatar
I wouldn't be surprised if touching the rubber piece skewed the MAF readings, especially if it's intermittent contact.
Logged the K&N today, and it is amazingly similar in calibration to the Hahn. Like nearly dead on.
Old Oct 11, 2011 | 05:54 PM
ford's Avatar
If you are worried about it, go log the car and tap on the maf. See what happens!
Old Oct 12, 2011 | 01:09 PM
seeyaass's Avatar
Mine fits perfect, sturdy, I couldn't move it if I wanted to lol.
Old Oct 12, 2011 | 01:18 PM
07SSYellow's Avatar
Resident Post Whore/Troll
mine sits a little farther back i can fit a finger inbetween mine, i have solid mounts all around
Old Oct 12, 2011 | 02:06 PM
RYRO14's Avatar
My stage 2 mounts have caused mine to rub there as well, not a big deal as it doesnt cause any issues with the fuel trims at all.
Old Oct 12, 2011 | 06:08 PM
brandondrecksage's Avatar
dumb question, but do you have the intake part all the way on the coupler that goes on the turbo? mine first looked like yours and then i realized it could go on another half inch and then it was good. I have stock mounts though.
DarrenGC
Dec 24, 2021 01:55 PM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
OrangeCoba
Sep 25, 2015 06:06 PM
