K04r how many pounds
Old Oct 27, 2018 | 08:47 PM
sS07NA's Avatar
Picked up a lnf with a k04r, hot side charge pipe, catless dp, custom 2.5 exhaust w/res delete, magnaflow muffler, fmic, forge bpv. Question is how many pounds should I be roughly running? Currently at 23lb, thx in advance
Old Oct 28, 2018 | 07:05 AM
63 Nova SS's Avatar
What fuel, and who tuned it?
Old Oct 28, 2018 | 07:19 AM
sS07NA's Avatar
91, kevin Moyer
Old Oct 28, 2018 | 12:52 PM
Sounds about right on 91
Old Oct 28, 2018 | 02:58 PM
sS07NA's Avatar
only ask because I seen others run 26-28lb
Old Oct 28, 2018 | 04:58 PM
Tdubbs's Avatar
That 26+lbs is gonna happen with E only. My guess is 23 is the limit with 91, might be able to go a smidge more on 93, but E47 will be your go to for higher unless you want to spray meth.
Old Oct 28, 2018 | 06:14 PM
sS07NA's Avatar
gotcha... 93 isnt available here in cali and e85 isnt every where either 😫
Old Oct 28, 2018 | 11:00 PM
I think I was running around that much boost when I had my R but I was using e47
Old Oct 29, 2018 | 03:17 PM
Tdubbs's Avatar
See if you can find an oil dealer that has E98 by the barrel. Around me it's about $200 plus barrel deposit for 55gal, then just blend it with the 91.
I started doing it from Kevin's suggestion, running E32 currently (3:1 93/E98) with no notable downsides, at least for my goals.
Old Oct 30, 2018 | 08:55 AM
63 Nova SS's Avatar
Mixing the 93 with e98 is probably as good as doing e47 the way I did because e85 is blended with 87 octane and not 93 so your octane is a lot higher in your method at e32.
cobaltssdude420
Sep 13, 2017 11:48 PM
Geo_SS
Jan 23, 2015 12:30 PM
spina74
Sep 5, 2013 04:45 PM
mattdracing
Jan 13, 2012 08:12 AM
kplaya186
Sep 30, 2011 09:50 PM
