Kmo43 2016
#727
A huge thanks goes out to Mongo. Im buying a LDK and he's switching out the block to the 2.4 like I need and will be tapping the block for the turbo oil feed!. He's hooking me up!!
#728
I'm going with opels and E45 so I will be posting all the fuel data I get from running a high hp level with these mods and with / without meth. I may even start a new thread just to discuss E mixtures on an LNF. I'll be running around 1000cc/min meth so a bit more than a ZZP 80lb 5th setup. I'm thinking I'll be able to run more than E45 but with the E98 and 94 mix I'll be able to achieve my goals only on E45 and I don't really wanna buy a new barrel every month
#733
I'll be using the same turbo and I have no future plans to change I really want to see what the 71 is capable of and the only reason why I'd swap is if I can't make my goals with it
#735
Now u know why I think i can get the K04 dyno record if I wanted. There are no rules on engine mods. So my 2.1L high compression gapless ringed engine would be legal. Stg2 cams ported head plus all the E and meth I can spray at the thing
#738
It wouldn't really be fair but it's within the rules. Who does a crazy build and slaps a K04 on there? No one is that dumb......
#739
When I hit the rollers I'm gonna do a 27psi pull because I wanna see how much I gained from this bottom end build I think its gonna gain an easy 30 to 40hp
#741
No thats dumb
#744
And asking me to blow up my engine and risk 1000s of dollars worth of parts is? I just pointed out that a dumb suggestion was dumb
#745
user 72239 (08-12-2016)
#747
Haha ok then
#748
ZZP says you can't use the 4 bars on the LNF
KMO43 (08-05-2016)
