LDK intake on LNF
LDK intake on LNF
Hey guys, I got an LDK intake for the my LNF, is there anything I need to get to make sure everything bolts up and goes back in alright? I was hearing that the MAP sensor needs a different kind of o-ring or something to fit. Anything else I need to know?
The ldk manifold does not have provisions for the 2 bar sensor. you need to drill an additional hole for it. Also the 3 bar does not fit 100% you need to remove the metal sleeve and dremmel the hole slightly to get it perfect.
yup only difference is the map sensor hole is made for 3bar, it only has one screw hole where the stock lnf needs 2, and no matter how u try lnf map will not go in, unless u drill it out, I tried
Awesome, I am running the 3-bar MAP sensors.
I got it so I can have it powdercoated and still use my car while that's getting done.
patooyee
Oct 1, 2015 01:07 PM
