Leaking Turbo
Old Mar 12, 2012 | 02:05 AM
JacBlackSS/TC's Avatar
Leaking Turbo
Swapped turbos out today and i am still suffering from a oil leak from the top dead center banjo fitting, finally inspected the bolt today and it looked a tad bit stripped, hopefully when i order another one that cures the problem. I have had a leak in the same spot on a previous turbo but it was more of a drip, the new one just pours out
Old Mar 12, 2012 | 02:09 AM
elecblue06's Avatar
hmm I have a leak and I can't find out where it is.. maybe I'll check this one
Old Mar 12, 2012 | 06:53 AM
ctn2mb's Avatar
because racecar
Old Mar 12, 2012 | 07:07 AM
FasterIsBetter's Avatar
Did you get a new banjo gasket? There is supposed to be a gasket there.
Old Mar 12, 2012 | 08:35 AM
Axelthered05's Avatar
that so called "gasket" is just a metal washer its not even a crush washer
Old Mar 12, 2012 | 08:40 AM
Yeah, but it has a coating on it that rubs off and helps seal.
Old Mar 12, 2012 | 09:18 AM
tomj77's Avatar
Don't u put Teflon on the threads?
Old Mar 12, 2012 | 09:35 AM
I'm gonna order a new bolt and gasket I reused the old one which needed to be replaced once I find the part number
Old Mar 12, 2012 | 09:40 AM
rallycobalt06's Avatar
so the old turbo is still good?
Old Mar 12, 2012 | 09:49 AM
oil feed banjo bolt $16.40 at GMPD 11561946
oil feed washer $2.66 at GMPD 12626102
Old Mar 12, 2012 | 09:50 AM
Yeah I'm thinking it's not trashed and it may have been that bolt when I get this new one I'm gonna put it in the one that's in now if it still leaks then I will swap them out
Old Mar 12, 2012 | 09:54 AM
09CobaltSS1's Avatar
Are you leaking from the oil line, or coolant line?
Believe it or not, the gaskets do crush down a bit a score due to them being copper. I would avoid re-using the gaskets to avoid this exact issue. They are cheap enough and relatively easy to find.
Old Mar 12, 2012 | 10:03 AM
hopefully this is the issue it was pouring out like a fountain
Old Mar 12, 2012 | 10:16 AM
elecblue06's Avatar
oil remember
Old Mar 12, 2012 | 10:18 AM
Not to ask a stupid question, but did you put a washer on each side of the banjo fitting (bolt head side and turbo side)?
It could be an easy thing to accidentally miss so I'm just making sure..
oil remember
No i don't remember actually....
Go on AIM
Last edited by 09CobaltSS1; Mar 12, 2012 at 10:18 AM. Reason: Automerged Doublepost
Old Mar 12, 2012 | 10:20 AM
wait i'm suppose to use a crush washer AND the banjo fitting????
Old Mar 12, 2012 | 10:24 AM
lol.. wait, what?
I'm not sure how to take that post. So I'll just answer it seriously.
There should be a copper washer on each side of the banjo fitting. One between the banjo fitting and the bolt head, and another between the bottom of the banjo fitting and the turbo. It needs to seal on both sides of the fitting don't forget
Old Mar 12, 2012 | 10:27 AM
no i was being 100% serious i thought it was only suppose to be the banjo fitting so does the bolt come with the new fitting and i just need to order two of the oil feed washers and i should be good to go when i took it apart before i don't remember it being copper washers
Old Mar 12, 2012 | 10:34 AM
I can't say for sure, but it should come with the washers and bolts. Are the bolts that were on there trashed?
Old Mar 12, 2012 | 10:38 AM
the one where the leak is coming from is stripped at the bottom so i can buy a new one the other ones are fine its only leaking from that one spot
Old Mar 12, 2012 | 10:44 AM
Here's a basic pic of what you should be seeing. Granted this is not our turbo, but it's still the same idea when it comes to banjo bolts. Notice between the bolt head and the banjo fitting there is a copper washer. There will be another copper washer below the fitting where it meets with the turbo.
[IMG][/IMG]
Old Mar 12, 2012 | 10:54 AM
ahhh i see
Old Mar 12, 2012 | 11:40 AM
No, its not a copper washer on ours. Its a gasket that has two rings attached to each other by a strand of gasket and each ring goes on a side of the banjo fitting on the line with the banjo bolt going through it.
Old Mar 12, 2012 | 11:50 AM
so its just the banjo fitting gasket that goes around the bolt correct or do i use the fitting with two washers i'm getting confused now
Old Mar 12, 2012 | 02:41 PM
mazda_2_pontiac's Avatar
it sounds as though it goes turbo, gasket, banjo, gasket, and bolt ties everything together
