Limp mode
Old Aug 16, 2014 | 03:30 PM
murlin15's Avatar
Limp mode
My car is throwing a p0299, p2178, p2187 which is under boost, vacuum leak, and exhaust leak. The dealership think it's do to aftermarket part. Any other ideas?
Old Aug 16, 2014 | 04:04 PM
Sl0wbaltSS's Avatar
What aftermarket parts?
Old Aug 16, 2014 | 05:42 PM
SSlobalt's Avatar
See if the vac line going to your cold side pipe has broken off at the nipple. Bypass vac tank to test for leaky tank.
Old Aug 16, 2014 | 06:14 PM
murlin15's Avatar
Upper Charge pipe, Cold air intake and Hahn Down pipe and cat back exhauts
Old Aug 16, 2014 | 08:39 PM
murlin15's Avatar
where is the vac tank on the coldside?
Old Aug 17, 2014 | 12:44 PM
SSlobalt's Avatar
Sorry. That was two separate things. Look at your cold side pipe. Locate the TMAP sensor. There is a hose right next to that sensor that goes to a solenoid on top of the intake manifold. Sometimes, the barb on the pipe that the hose attaches to, breaks off. Make sure that is not broken.
I don't have access to my computer right now, so I can't show you pics of the vac tank. It's under the intake manifold. Sometimes they leak and need to be bypassed.
Also, check the BPV diaphragm for tears. When I get back home, later today, I'll post pics of all of this stuff.
Old Aug 17, 2014 | 10:25 PM
murlin15's Avatar
Its not the vac tank I just bypassed it today how to I tell of map sensor is bad?
Old Aug 18, 2014 | 12:32 PM
SSlobalt's Avatar
This isn't really a code associated with a bad TMAP sensor. You can sometimes tell they are bad when you register boost while revving in neutral.
The hose is still connected to your coldside pipe then? It's the hose that has the green clamp on it, in the pic.
If that tube is still connected, I would definitely check the BPV diaphragm for a tear. It is behind the tan cover on your turbo. It's kind of hard to get to, but not too bad.
Old Aug 20, 2014 | 11:54 AM
murlin15's Avatar
Could a untuned car cause a code because I have the Hahn cai with no maf tune? Just curious
Old Aug 20, 2014 | 12:14 PM
tomj77's Avatar
Not likely I had that and it didnt
Old Aug 20, 2014 | 04:47 PM
murlin15's Avatar
well im running out of ideas
Old Aug 21, 2014 | 11:56 AM
murlin15's Avatar
Cracked intercooler maybe it starts whistling when I'm almost out of vacuum like at 10hg.
Old Aug 23, 2014 | 12:54 PM
SSlobalt's Avatar
Pull the bumper cover when you do your boost leak test.
Old Aug 23, 2014 | 05:48 PM
reybalt's Avatar
Do you have gms1?
Old Aug 23, 2014 | 09:34 PM
SSlobalt's Avatar
Originally Posted by reybalt
Do you have gms1?
No, I have HPT e47.
Old Sep 4, 2014 | 01:25 PM
murlin15's Avatar
what codes come up when you have a cracked intercooler or a torn bpv? just curious
Old Sep 25, 2014 | 01:57 PM
murlin15's Avatar
how do you change a wastegate solenoid and what is the best replacement one for a stock turbo
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
Dustonian131
Sep 23, 2015 08:03 PM
bucks121
Sep 12, 2015 07:39 PM
