A little teeaking !
the intake may....throw some odd ltft's and reduce power some...but maybe first isntall the full turbo back, reset the battery and see how it is after some miles, then put the intake in and see what happens.
A cat-back exhaust doesn't help our cars much at all it's all about the down pipe. And an intake probably won't add you any power gains on GMS1 (unless you tune for it specifically with an aftermarket tune) intake will give you more trouble than it's worth.
Why ? are you thinking learn down because of the nature of the computer ?
no if you arent tuned for a intake it just can make your car run like crap because NONE of the current intakes for the lnf cobalt work properly and skew the **** out of your ltft and stft's. If you read the intake thread(s) you'll find more information, but bad intakes can bog your car, run it too rich, run it too lean.
https://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/thoughts-all-intakes-currently-avaliable-ss-tc-206581/
[QUOTE=northvibe;4836558]no if you arent tuned for a intake it just can make your car run like crap because NONE of the current intakes for the lnf cobalt work properly and skew the **** out of your ltft and stft's. If you read the intake thread(s) you'll find more information, but bad intakes can bog your car, run it too rich, run it too lean.
https://www.cobaltss.net/forums/showthread.php?t=206581[/QUOTE
I just canceled the intake.....I have read too much bad print on all of them....I can do that later when the waranty is gone when I replace the cams and tune it up....
[QUOTE=crypticscifer;4836726]
Took some work though. 8 logs total. Still some turbulance because the MAF is so picky about how the air hits it. Hopefully someone will have a solution for me to test soon... That reminds me, I have to make a phone call.
Yeah, turns out the day I went to install my spring... yeah I lost it.... long story. I have to wait on that.
[QUOTE=RJT;4836708]
good call, I currently just have a k&n drop in filter and a stage 1 gm kit. I havent data logged yet, but I have a dash hawk to do so. I was going to make some logs of stock and w/ the drop in so we can have logs on the site in a sticky for reference.
[QUOTE=Terminator2;4836809]
Would something like one of these work:
or...
or...
if you want a stable intake temporarily that has less troubles go for Hahn CAI, then you might see somthing. Just waiting mine in the mail because its in hot demand. You should get a CP either from OTTP, ZZP, or Injen.
