LNF Basics for making more power
Old Jan 19, 2016 | 12:17 AM
  #51
Direnight's Avatar
I wonder is there a list of Tunes some where i live in Atlanta & was thinking of Moding my car just have not made up my mind yet.
Old Jan 19, 2016 | 08:47 AM
  #52
blueLNFftw's Avatar
Forge BPV are NOT an upgrade. They are a pain in the dick and not worth the $150.00 at all. They are too stiff even on the lowest spring and cause BPV solenoid issues as they are slower compared to stock. The stock BPV is the best choice.
You should NOT run a vent to atmosphere BPV or BOV without a tune, on the OEM BPV solenoid, and a MAF relocate it HIGHLY recommended to avoid rich spikes from releasing metered air. When doing the MAF relocate you can simply cut the plastic wire loom open and pull out the wires to move the MAF plug to its new location. No harness or wire cutting is needed on the Cobalts.
Old Jan 19, 2016 | 07:02 PM
  #53
63 Nova SS's Avatar
Good advice!
Old Jan 20, 2016 | 09:21 AM
  #54
blueLNFftw's Avatar
Good advice!
I wish more people would listen lol.
I have had a dollar for every argument I have caught over my analysis of the stock BPV solenoid, MAF relocate and VTA on blow through set ups, I would have a free s257 swap on my car lol
Old Jan 20, 2016 | 10:00 AM
  #55
umrdyldo's Avatar
Find Term2, drive to see him.
Old Jan 20, 2016 | 10:02 AM
  #56
blueLNFftw's Avatar
What car do you have?
Old Jan 20, 2016 | 12:12 PM
  #57
guys - havent looked at this thread much since i made it. any additions/changes i need to make to the OP?
Thanks!
Old Jan 20, 2016 | 12:26 PM
  #58
blueLNFftw's Avatar
Post #52
Add to it that a BPV, BOV, or MAF relocate are not power adders. People seem to think they are.
Old Jan 20, 2016 | 01:37 PM
  #59
Affirmative. Idk why anyone thinks they are lol. They do sound cool though which is worth 5hp in my book
Old Jan 20, 2016 | 01:55 PM
  #60
blueLNFftw's Avatar
The replacement BPV's do not function right which is why they make the sound they make lol
Old Jan 20, 2016 | 02:32 PM
  #61
blu3_v1p3r's Avatar
Forge Bypass Valve is a pain in the dick? How so? Installation was simple. Also the lightest spring is equivalent to stock. I've had mine for 2 years with not a single issue from it. I'm not a believer that they are slower then the stock BPV. Is there anything you can show that backs this information up? I do agree that it is not a power adder. I got mine because my stock BPV got stuck open, and the diaphragm started to tear.
Old Mar 9, 2016 | 09:55 PM
  #62
theamericono's Avatar
so if i understand this correctly the 3 bar map sensor just senses a more accurate boost pressure correct. And the HPtuner is that a specific brand or is the a couple of hptuners
Old Mar 9, 2016 | 10:10 PM
  #63
3bar increases the boost the ecu can see accurately. Hptuners is a hardware and software that allows you to either tune the car yourself or have someone remote tune you or in person tune you
Old Mar 9, 2016 | 10:41 PM
  #64
Direnight's Avatar
I have a 2009 4 Door Cobalt SS Turbo Silver i believe i put picks on my account if you wanted to see.
Old Mar 9, 2016 | 10:42 PM
  #65
Direnight's Avatar
I have a 2009 4 Door Cobalt SS Turbo Silver i believe i put picks on my account If you wanted to see it.
Old Aug 16, 2016 | 11:35 PM
  #66
Scypheroth's Avatar
and what about us canadians that dont have access to Ethanol fuel? all we got in my area is 10% ethanol fuel of 92 and 94 octaine
Old Aug 16, 2016 | 11:47 PM
  #67
Canadia's Avatar
meth
Old Jan 19, 2017 | 10:53 AM
  #68
KINGMAROSS's Avatar
What process is required when switching from 93 to ethanol fuel?
Old Jan 19, 2017 | 12:01 PM
  #69
umrdyldo's Avatar
Depends if you want to go with full E85, E47, E30 etc. At a minimum you need a retune. If you want to run full E85 you will need upgraded cam and probably injectors.
You can run E30 with just a retune usually.
Old Feb 24, 2018 | 10:11 AM
  #70
LnFitness's Avatar
Gms1
If I had gms1 sensors do I need to get a custom tune for the effect or can I just install and I’m good to go?
Old Feb 24, 2018 | 10:49 AM
  #71
You will need a tune to run the sensors. Either the gms1 tune or a custom tune
Old Feb 24, 2018 | 12:39 PM
  #72
63 Nova SS's Avatar
This^ if I remember right it will go into limp mode.
Old Feb 25, 2018 | 12:25 PM
  #73
umrdyldo's Avatar
Originally Posted by Pasierbek
Wow what a great thread for an LNF beginner. Thank you for starting this up! One question though, I heard you have to cut your stock exhaust to install a downpipe. Is that true?
Also in regards to transmission, I heard the throw out bearing is not very durable.
No the stock downpipe is removed as one piece and is replaced with no cutting. If you replace the catback portion of the exhaust you have to cut the stock catback
The TOB is really only an issue for people that replace the clutch. Some people install the new TOB wrong and it leads to issues
Old Feb 25, 2018 | 05:10 PM
  #74
LNFwagonSS's Avatar
Zzp's newly released upgraded HPFP and mongorats LT4 pump adapter kit should be added to thread.
Old Aug 28, 2018 | 02:11 PM
  #75
06stockss's Avatar
Hey guys I live in Denver Colorado right now on 91oct pump has just few bolt on like downpipe zzp catless zzp bigger intercooler zzp trans mount and I have a intake from k@n have not put that on yet it’s my daily drive but my goal for it is like 305-310who and 330-340ftq To. Right now has the zzp canned tuned and did 285hp 314ftq on 20psi that all I can do pretty since I don’t have charge piping change yet will soon tho
