lnf Fuel pressure
Old Nov 3, 2018 | 03:45 AM
Badbowtie's Avatar
lnf Fuel pressure
I have a 2008 lnf with just bolt ons stock fuel system.
im on full e with a tune but i keep losin fuel pressure even when i was on e47 it would sputter at a high rpm and now at a high rpm it just falls on its face and sends me the code along with reduce engine power. Idk where to start besides with the HPFP but don’t want to throw my money away any ideas? Btw cr has 102k miles
Old Nov 4, 2018 | 12:06 AM
tomj77's Avatar
What turbo? What kinda tune? If its running out of fuel up top you obviously need fuel mods. Definitely if ur over e47. Need opels and cam with bigger cam lobe for the pump. If ur on big turbo and trying to run e85 u will need lt1 pump
Old Nov 4, 2018 | 12:42 AM
Badbowtie's Avatar
i have a stock turbo
Old Nov 7, 2018 | 08:08 PM
tomj77's Avatar
im not 100 percent sure what u need on stock turbo....I think just the opels injectors.
Old Nov 8, 2018 | 10:08 AM
armcclure's Avatar
i'm assuming you replaced the injectors/seals?
Old Nov 10, 2018 | 08:18 AM
63 Nova SS's Avatar
You should have plenty of fuel running e47 at higher rpm. Don't even need opels for that. Sure your not getting spark blowout? Any misfire codes? I run e47 on a slightly bigger wheeled k04 and it loves it. Do you have a way of logging it to check and see what your pressure is dropping to?
Old Nov 10, 2018 | 02:16 PM
Same here running e47 on a bigger turbo and dnt run out of fuel
Old Nov 10, 2018 | 03:40 PM
Try the top of 4th gear
Old Nov 10, 2018 | 11:18 PM
When the car runs lol
Badbowtie
Apr 25, 2024 10:22 AM
Badbowtie
Nov 4, 2018 01:39 PM
Feb 3, 2017 02:17 PM
Nfamous60
Oct 9, 2012 10:45 AM
