LNF information
Old Nov 2, 2007 | 10:20 PM
MaJ's Avatar
MaJ
Originally Posted by OniMirage
at this rate it won't be until 2009 till everything is stable enough for an sc owner to jump to a tc. I woudn't wanna go through another set of years before things leveled out. First year with the balt nothing second year finally some decent upgrades 3rd year things are great ... then it was dropped. At least that gives time to save money.
Your kidding me right?
I have to appologize here. I read your first post completely wrong. In my inability to read the English language, your first post came out (to me anyway) as saying "at this rate it won't be until 2009 before everyone is stable enough for an sc owner to jump to a tc." Hence my reference to the financial situation of SS/SC owners.
My bad. I bow to your superiority.
Old Nov 3, 2007 | 12:32 AM
rukkee's Avatar
Hehhe i was wondering why you said something about not having any trouble paying for yours .
OniMirage is right about the aftermarket , i lurked on these boards for 8-9 months before buying my ss/sc , then i joined . It was almost the exact same speculation about stage kits and tuning for the SC back then as it is now for the TC .
Old Nov 3, 2007 | 01:06 AM
jimbos'ss's Avatar
Your kidding me right? I bought the cobalt the first ******* year it came out there was NOTHING for this car that was quality enough to use. torque dampeners twisted, intakes had fit issues, mounts didn't help wheel hop, piggyback systems caused drivability issues. Going into the second year there were stage kits, decent intakes that corrected fit issues, some mods caused cels or limp mode, HPT made a great appearance and helped alot, GM's own kits had an update to correct drivability issues. Going into the 3rd now and there are lots of good mods and upgrades and the market has matured enough that people can mod how they want the car to be.
I still say 2009 is when people will consider the tc as a trade in for the sc since there is nothing out for the car right now and its still months away from even being released.
So before you start saying I don't know **** about people that own the cobalt how about looking at the join date of the person your talking to.
x10000, in 05 there wasn't anything out for this car. now i have over 5grand in mods. this year has been the best for the ss/sc sofar now it's all gonna go away with the new lnf balt coming out. which is why i'm doing my own turbo conversion
Old Nov 4, 2007 | 05:12 AM
Sleepyguy's Avatar
Engine Mechanical Specifications Application
Specification
Metric
English
General Data
Engine Type
Inline 4 Cylinder
Displacement
2.0 L
122 CID
RPO
LNF
Liter (VIN)
M
Bore
85.992-86.008 mm
3.3880-3.3887 in
Stroke
86 mm
3.388 in
Compression Ratio
9.2:1
Balance Shaft
Bearing Clearance
0.030-0.060 mm
0.0012-0.0024 in
Bearing Diameter - Inside - Carrier
20.050-20.063 mm
0.7894-0.7899 in
Bearing Diameter - Outside - Carrier
41.975-41.995 mm
1.6526-1.6534 in
Bearing Journal Diameter
20.000-20.020 mm
0.7874-0.7882 in
Bushing Clearance
0.033-0.102 mm
0.0013-0.0040 in
Bushing Diameter - Inside
36.775-36.835 mm
1.4489-1.4512 in
Bushing Journal Diameter
36.723-36.743 mm
1.4458-1.4466 in
End Play
0.050-0.300 mm
0.0020-0.0118 in
Block
Balance Shaft Bearing Bore Diameter - Carrier
42.000-42.016 mm
1.6535-1.6542 in
Balance Shaft Bushing Bore Diameter
40.763-40.776 mm
1.6048-1.6054 in
Crankshaft Main Bearing Bore Diameter
64.068-64.082 mm
2.5224-2.5229 in
Cylinder Bore Diameter
85.992-86.008 mm
3.3880-3.3887 in
Cylinder Bore Out-of-Round - Maximum
0.010 mm
0.0004 in
Cylinder Bore Taper - Maximum
0.010 mm
0.0004 in
Cylinder Head Deck Surface Flatness - Longitude
0.050 mm
0.002 in
Cylinder Head Deck Surface Flatness - Overall
0.10 mm
0.0039 in
Cylinder Head Deck Surface Flatness - Transverse
0.030 mm
0.0012 in
Camshaft
Camshaft End Play
0.040-0.307 mm
0.0016-0.0121 in
Camshaft Journal Diameter
26.935-26.960 mm
1.0604-1.0614 in
Camshaft Journal Diameter - Front
34.960-34.935 mm
1.3774-1.3764 in
Camshaft Thrust Surface - with Camshaft Actuator Installed
30.020-30.175 mm
1.1828-1.1889 in
Connecting Rod
Connecting Rod Bearing Clearance
0.029-0.073 mm
0.0011-0.0029 in
Connecting Rod Bore Diameter - Bearing End
52.118-52.134 mm
2.0519-2.05252 in
Connecting Rod Bore Diameter - Pin End
23.007-23.017 mm
0.9058-0.9062 in
Connecting Rod Side Clearance
0.070-0.370 mm
0.0028-0.0146 in
Connecting Rod Straightness - Bend - Maximum
0.021 mm
0.0083 in
Connecting Rod Straightness - Twist - Maximum
0.04 mm
0.0157 in
Crankshaft
Connecting Rod Journal Diameter
49.000-49.014 mm
1.9291-1.9297 in
Crankshaft End Play
0.050-0.380 mm
0.0012-0.0150 in
Crankshaft Main Bearing Clearance
0.031-0.067 mm
0.0012-0.0026 in
Crankshaft Main Journal Diameter
55.994-56.008 mm
2.2045-2.2050 in
Cylinder Head
Deck Straightness - in 150 mm (5.91 in)
0.05 mm
0.0019 in
Deck Straightness - in 25 mm (0.985 in)
0.025 mm
0.0009 in
Between Head Bolt Holes
0.030 mm
0.0011 in
Surface Flatness - Block Deck - Longitude
0.050 mm
0.002 in
Surface Flatness - Block Deck - Overall
0.1 mm
0.004 in
Surface Flatness - Block Deck - Transverse
0.030 mm
0.0012 in
Valve Guide Bore - Exhaust
6.000-6.012 mm
0.2362-0.2367 in
Valve Guide Bore - Intake
6.000-6.012 mm
0.2362-0.2367 in
Valve Lifter Bore Diameter - Stationary Lash Adjusters
12.013-12.037 mm
0.4730-0.4739 in
Lubrication System
Oil Pressure - Minimum - @1000 RPM
344.75-551.60 kPa
50-80 psi
Oil Capacity
4.8L
5.0 quarts
Piston Rings
Piston Ring End Gap - First Compression Ring
0.20-0.35 mm
0.0078-0.0138 in
Piston Ring End Gap - Second Compression Ring
0.35-0.55 mm
0.014-0.022 in
Piston Ring End Gap - Oil Control Ring - Rails
0.25-0.75 mm
0.010-0.030 in
Piston Ring to Groove Clearance - First Compression Ring
0.040-0.080 mm
0.0016-0.0031 in
Piston Ring to Groove Clearance - Second Compression Ring
0.003-0.068 mm
0.0001-0.0027 in
Piston Ring to Groove Clearance - Oil Control Ring
0.024-0.176 mm
0.0009-0.0069 in
Piston Ring Thickness - First Compression Ring
1.170-1.190 mm
0.0461-0.0469 in
Piston Ring Thickness - Second Compression Ring
1.471-1.490 mm
0.0579-0.0587 in
Piston Ring Thickness - Oil Control Ring - Rail - Maximum
0.473 mm
0.0186 in
Piston Ring Thickness - Oil Control Ring - Spacer
0.96-1.04 mm
0.0378-0.0409 in
Pistons and Pins
Pin - Piston Pin Clearance to Connecting Rod Bore
0.009-0.023 mm
0.0004-0.0009 in
Pin - Piston Pin Clearance to Piston Pin Bore
0.005-0.015 mm
0.0002-0.0006 in
Pin - Piston Pin Diameter
22.995-23.000 mm
0.9053-0.9055 in
Pin - Piston Pin End Play
0.320-1.278 mm
0.0126-0.0503 in
Piston - Piston Diameter - @14.5 mm up
85.967-85.982 mm
3.3845-3.3851 in
Piston - Piston Pin Bore Diameter
23.005-23.010 mm
0.9057-0.9059 in
Piston - Piston Ring Groove Width - Oil Control
2.001-2.003 mm
0.0788-0.0789 in
Piston - Piston Ring Groove Width - Second
1.52-1.54 mm
0.0598-0.0606 in
Piston - Piston Ring Groove Width - Top
1.23-1.25 mm
0.0484-0.0492 in
Piston - Piston To Bore Clearance
0.010-0.041 mm
0.0004-0.0016 in
Valve System
Valves - Valve Face Runout - Maximum
0.04 mm
0.0016 in
Valves - Valve Seat Runout - Maximum
0.05 mm
0.0020 in
Valves - Valve Stem Diameter - Exhaust
5.935-5.950 mm
0.2337-0.2343 in
Valves - Valve Stem Diameter - Intake
5.955-5.970 mm
0.2344-0.2355 in
Valves - Valve Stem to Guide Clearance - Exhaust
0.050-0.077 mm
0.0020-0.0026 in
Valves - Valve Stem to Guide Clearance - Intake
0.030-0.057 mm
0.0012-0.0022 in
Valve Lifters - Valve Lifter Diameter - Stationary Lash Adjuster
11.986-12.000 mm
0.0005-0.0020 in
Valve Lifters - Valve Lifter-to-Bore Clearance - Stationary Lash Adjuster
0.013-0.051 mm
3.2210-3.2299 in
Valve Springs - Valve Spring Load - Open - @22.5 mm
525.0-575.0 N. - Eng Spec.
Valve Springs - Valve Spring Load - Closed - @32.5 mm
245.0-271.0 N. - Eng Spec.
Old Nov 4, 2007 | 10:59 AM
Archie's Avatar
Very good info for someone wanting to rebuild for higher hp applications, 600hp+.
+ imaginary Rep.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
ashalle2
Sep 27, 2015 03:28 PM
