Lnf problems :(
Old Aug 26, 2015 | 09:06 PM
reybalt's Avatar
Lnf problems :(
Hey guys, my 09 SS has been having problems. The car has a misfire and the rpm needle drops and goes back up when it's on neutral coming to a stop. Could it be a dirty throttle body? Or dirty maf? Btw. It's running lean and it has a brand new ldk installed. Any help will be great. Thanks
Old Aug 26, 2015 | 09:11 PM
footballplaya3k's Avatar
Lnf problems :(
Have you boost-leak tested?
Old Aug 26, 2015 | 09:23 PM
reybalt's Avatar
Lnf problems :(
I haven't. I will do that tomorrow. I recently installed an aftermarket lower charge pipe and then all these problems started to occur.
Old Aug 26, 2015 | 11:07 PM
Lnf problems :(
That could be it. What charge pipe?
Old Aug 26, 2015 | 11:09 PM
reybalt's Avatar
Lnf problems :(
Hahn
Old Aug 27, 2015 | 12:38 AM
Scary. Watch out for rust.
Old Aug 27, 2015 | 02:32 AM
Sl0wbaltSS's Avatar
Running lean on a new ldk? get retuned. Def don't stay on oem LNF or gms1
Old Aug 27, 2015 | 11:08 AM
reybalt's Avatar
Lnf problems :(
It's currently on gms1. Why don't you recommend the gms1?
Old Aug 27, 2015 | 11:13 AM
Dont listen to him.
The rpm dropping is most likely connected to a vacuum or boost leak probably from the lower charge pipe. Start there, when you installed the LDK did you use new AC Delco plugs? And then the break in period was followed?
Old Aug 27, 2015 | 11:25 AM
reybalt's Avatar
Lnf problems :(
I bought the ldk long block from zzp. It already came with spark plugs but i have (new) spare spark plugs. However i did leave my aftermarket c.a.i. installed. Not sure if that can cause it.
Old Aug 27, 2015 | 11:26 AM
Which intake?
Old Aug 27, 2015 | 11:28 AM
reybalt's Avatar
Lnf problems :(
Aem cold air intake.
Old Aug 27, 2015 | 11:42 AM
Lnf problems :(
Do you still have the stock one kicking around? If so put that on till you can get the issue straighten out then try the AEM intake again
Old Aug 27, 2015 | 12:00 PM
umrdyldo's Avatar
For sure sounds like a boost leak probably in lower charge pipe.
Do you have any way to monitor the car? You should be watching your fuel trims and such.
Especially after a new install. You have no idea how it's running and could hurt the new engine.
Old Aug 27, 2015 | 11:43 PM
Sl0wbaltSS's Avatar
I had a huge hole in my OEM intercooler and it idled perfect and AFR's were perfect. Just no power
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
