LNF Rocker Arms?
Old Mar 30, 2013 | 10:42 AM
damastah's Avatar
LNF Rocker Arms?
So I have the car back to stock kinda atm. Stock charge pipe blew off yesterday and while the car was warming up today, i decided to put it back on and fix the clamp..
it was a cold start when i started working on it. and was on for about 10-15 minutes and about for 2-3 seconds I would hear knocking....
I only heard it about twice... Not sure why it was making the noises... Was not loud either...
Was trying to determine where the sound was coming from, but since the sound was so faint, and only there for a few seconds at a time, i could not determine where it was coming from. But it sounded like it was coming from my rocker arms... and it sounded like rocker arms too...
have any of you experienced issues with your stock rocker arms?
i'm a 2010 and i just hit 30k miles btw
Old Mar 31, 2013 | 09:35 AM
QuickSilver_SS's Avatar
I have read several threads where a few people have broken a couple of there rocker arms on there lnf's. If i remember correctly it was mostly caused by running high in the rpm range and or over reving past what the stock rev limiter was set at. Like a after market tune that allows you to rev past the stock 6300 - 6500 rpm. Say around 6600 or 6700 rpm. And then if i remember a few people broke there rocker arms.
Why did you return your car to stock? Are you getting ride of it? Or because of the noise ?
Old Mar 31, 2013 | 09:53 AM
gotboost?17's Avatar
Nothin Stock
well heres a lil back round on mine, my motor was making a ticking noise every 5 seconds about, gm replaced all internals in the head but the rear cam shaft, and i go pick it up and still does it, im like its still there, brought another balt htere to compare after i made another apppontment, it was coming from the rear corner on #4 cylinder, in the end gm did a hole head replacement, and they tore the old head down again and still dint c anything, everythings fixed now tho, i do have a video around of the ticking
u can hear it at 4 and 7 seconds mainly
Old Mar 31, 2013 | 11:34 AM
AARON-SS-TC's Avatar
take your valve cover off and look at hat bad boy..should be clear as day if rocker arms or lash adjusters are bad...
Old Mar 31, 2013 | 11:43 AM
Nothin Stock
also usually if a rocker or lash is gone it shuts 2 cylinders down, but who knows each car is diff
Old Mar 31, 2013 | 02:04 PM
FasterIsBetter's Avatar
Possible your seal went in the timing chain tensioner. I forget who had that issue repeatedly! Maybe CudaJoe?
Old Mar 31, 2013 | 02:28 PM
Powell Race Parts's Avatar
quicksilver SS had the most likely scenario...
Old Mar 31, 2013 | 02:59 PM
Nothin Stock
a stethascope might help also to track it
Old Mar 31, 2013 | 07:40 PM
damastah's Avatar
no, stock because of warranty work. have to take it back to dealer again. i have the turboxs catless DP and their GT exhaust on. they haven't realized it yet lol..
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
Coballin13
Sep 25, 2015 08:43 AM
