Lnf stock flywheel
Lnf stock flywheel
Am I reading this right on ced.com. $141 for a lsj flywheel and $600 for a lnf flywheel? Wtf is so special lol. Zzp only wants $119 for a lnf stock flywheel
the flywheels are the same, u may have to deal with smaller locationn pins on the LSJ Flywheel with the LNF clutch cover, but thats the same thing that we deal with on the LSJ GMPP clutch upgrade, which uses the LNF clutch cover. Save ur money use the LSJ one from CED. Or try Mongorat for some good new ones, there is alot of excess production inventory from Lordstown floating around the internet.
Ill email them and double check..also. Will running a lsj flywheel have any negative effects? I know the lnf is heavier therefore leading to more torque and etc. Will the lsj actually take power/fail faster paired with a ky stage 3?
read my lips. the flywheels are the same. same casting number, same weight same everything. CED and me went through this, I had a bunch I purchased, and tripped over the fact. they are the same.GM said they were not. Cant double check the source, but they were incorrect as far as service parts are concerned. The pricing? GM cant double check the idiots that gouge the dealers that in turn then gouge the public,
its worse in canada. GM Canada stick 25% markup on all parts BEFORE any other costing (inventory overhead freight etc) is added. OUr parts here are redonkulous. I buy from CED. Import myself.
Nice to know as I'm getting ready to do a clutch and was curious what exactly they changed as the GM media during launch said they downsized the flywheel to fit a bigger clutch. I guess not.
ThoR294
Oct 4, 2015 08:44 PM
