Looking for help on boost gauge relocation
Old Dec 7, 2010 | 01:39 PM
Ben.Reilly's Avatar
Hello everyone,
I am acquiring the necessary parts to relocate my stock boost gauge to the bottom left portion of my instrument bezzle. So far, I have a single pod bezzle, and stock a pillar cover (no pod). I am assuming I will need to extend the stock wires coming out of the boost gauge to bring it down to where I need it, can anyone confirm? Also, does anyone know of any resources showing how to do this (not sure if its been done).
Thanks for the help!
Old Dec 7, 2010 | 08:23 PM
tomj77's Avatar
yes, just solder some longer wires onto the stock ones, all they are is power, ground, dimmer, and boost signal, u shouldnt have any issues, use a volt meter to find out which is which, id tell u but its been a long time since i spliced into them, so i forgot.
Old Dec 8, 2010 | 10:01 AM
Ben.Reilly's Avatar
Old Dec 8, 2010 | 10:49 PM
08SStc's Avatar
actually, you dont need to cut and splice anywires. if you take the trim IFO the dash off and take those few 7mm bolts out then remove the gauge cluster. you can the lift upper dash cover enough to pull the wiring harness for the stock Boost gaugelocation under it and to the front to where you want to put it. Ive done this to mine myself
Old Dec 9, 2010 | 09:17 AM
Ben.Reilly's Avatar
Thanks for the advice! Any pictures of your setup?
Old Dec 28, 2010 | 03:28 PM
Ben.Reilly's Avatar
Here are some photos of the finished product. As mentioned, no cutting or drilling required. Hardest part was getting the stock bezel out around the steering wheel:
Old Dec 29, 2010 | 03:50 PM
big_stu's Avatar
Looks really good. Where did you get the cluster surround with the gauge housing? Thanks!
Stu
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
