Looks like I need a new engine
Old 11-30-2016, 05:18 PM
  #151
colodude18's Avatar
Originally Posted by KMO43
I would recommend you check out ur turbo 1st. It would have been the 1st thing starved of oil
Yes I absolutely need to do that. I'm worried about that as well...
Old 11-30-2016, 05:24 PM
  #152
KMO43's Avatar
The 1st time it happened to me I sent mine to BW and they put it on a fancy turbo dyno
Old 11-30-2016, 05:25 PM
  #153
I second this. Although it didn't start screaming like a dying turbo does, it still needs to be checked out.
Old 11-30-2016, 05:37 PM
  #154
colodude18's Avatar
OK KMO where did you send yours, what did you need to do to set up this test and how much was it?
Old 11-30-2016, 07:52 PM
  #155
63 Nova SS's Avatar
I agree with kmo- you may not want to know what they say, but you still need to be sure before you sell that k04.
Old 11-30-2016, 08:38 PM
  #156
KMO43's Avatar
Mine did it the 2nd day I had it ao I sent it back and he sent it in
Old 12-01-2016, 01:40 AM
  #157
exninja's Avatar
I'd suggest to use your exhaust manifold from the lnf. The ldk is slightly different and would stress your downpipe more.
Old 12-01-2016, 07:47 AM
  #158
Omiotek's Avatar
I would not use the ldl manifold. It sits an inch higher then the lnf. None if the shielding fits, you will need to extend the drain etc etc
Old 12-01-2016, 09:07 AM
  #159
Did the shorten the LDK manifold runners? or just a random GM design change?
Old 12-01-2016, 09:50 AM
  #160
Omiotek's Avatar
The runners are different. I havent done testing for flow but even thougu the port openings are the same the runners seem to flatten put more
Old 12-01-2016, 10:14 AM
  #161
colodude18's Avatar
Jeffrey also told me to transfer over my crankshaft position sensor and obviously MAP sensors
Old 12-01-2016, 11:10 AM
  #162
It would be interesting to see the flow differences (if there are any)
Old 12-01-2016, 01:03 PM
  #163
exninja's Avatar
I am curious about why the CPS switch. I didn't (never heard of switching before now) and I don't have any issues that I'm aware of.
Old 12-01-2016, 02:16 PM
  #164
colodude18's Avatar
Only reason I couldmthink of was if the plug on the engine harness were different...I'll ask Jeffrey
why.
Old 12-01-2016, 02:21 PM
  #165
exninja's Avatar
I mean, it's easily done. I'm more curious if it's something I need to do (I sold mine believing it wasn't necessary).
Old 12-01-2016, 04:13 PM
  #166
colodude18's Avatar
Jeffrey said the plug is different. Maybe they changed something since you bought yours? Who knows. I'll try it out this weekend and report back.
exninja (12-01-2016)
Old 12-01-2016, 04:25 PM
  #167
exninja's Avatar
Yeah, ok, that's weird. Thanks for asking.
Old 12-01-2016, 04:29 PM
  #168
exninja's Avatar
I see you've got the brake booster pump on the LDK as well. You should hook that up, reach supermod baller status.
Old 12-01-2016, 05:05 PM
  #169
colodude18's Avatar
ECaulk is way ahead of you on this one, and is already looking into how to eliminate lag and improve my lap times with that thing
Old 12-01-2016, 06:15 PM
  #170
cw383's Avatar
I have the LDK manifold. I hate the higher turbo height and stress on downpipe/drain hose that doesn't fully seat. I'm going to swap in an LNF manifold. I put the engine/manifold turbo in the car all as one. How hard is it to remove/reinstall an exhaust manifold in car? Just wondering how tight everything is and if theres room to pull the manifold out, I don't know if anyones ever had reason to remove a manifold. I d love to hear if so. Sorry to hijack thread
Old 12-01-2016, 09:50 PM
  #171
exninja's Avatar
I don't think it's possible to do without removing the turbo, so add 30-60min to a turbo swap job.
Old 12-01-2016, 10:17 PM
  #172
cw383's Avatar
Yuck. I don't know its worth that much work. I think I may just lengthen my return line ( either fab or nipple in middle) and use rubber exhaust hangers instead of my poly's to give the exhaust some breathing room. Wish I knew the difference before the swap. Again, sorry to hijack
Old 12-01-2016, 10:22 PM
  #173
Its gonna take a little work, but easily do able
Old 12-03-2016, 07:39 AM
  #174
63 Nova SS's Avatar
Got all mine from Summit racing. This is everything for coolant and oil. I can't remember what fitting goes on the block itself. I think its another earl fitting
Anyone have an idea on the fitting that leemanfor couldn't remember, that goes to the block? Was going to order this stuff.
Old 12-03-2016, 08:22 AM
  #175
I want to say we had to order it from zzp, it's a non standard thread. This is from my two years ago so could be wrong, but I know zzp does sell one.
