LSD question
Old Mar 2, 2010 | 12:18 PM
cardelino18's Avatar
LSD question
ok so i know in a lot of 240sx cars they weld they diff. so they spin both tires...thats what they call a cheap LSD... my question is would this work for our car or just because its FWD it wont work?
Old Mar 2, 2010 | 01:24 PM
oopsitouchedmyself's Avatar
i don't think i'd do that. you might get wheel bind while turning. the lsd allows the tires to still turn at different speeds, but transfers power to the wheel with the most traction.
Old Mar 2, 2010 | 01:42 PM
northvibe's Avatar
theirs is rwd they can just do that to the rear diff, ours is fwd and the axels come right out of the transmission so no i dont think it would work.
Old Mar 2, 2010 | 02:05 PM
slapbetcommissioner's Avatar
have fun steering if you do. Strictly Drag Maybe LOL
Even they will have trouble crazy wheel hop throught corners unless you drift every one.. front wheel drive that meens not turning....
Last edited by slapbetcommissioner; Mar 2, 2010 at 02:05 PM. Reason: Automerged Doublepost
Old Mar 2, 2010 | 02:21 PM
northvibe's Avatar
cheapest is probably finding a salvage or used f35 trans w/ lsd in it.
Old Mar 2, 2010 | 04:23 PM
tom.g's Avatar
First of all if you weld your dif together it's not called a LSD it's called a locker (a cheap one at that) and second of all no this would not work on our FWD cars
Just stick witht he stock LSD and get some wider stickier tires, if you still can't hook up run a drag radial or a slick.
Old Mar 2, 2010 | 04:35 PM
Terminator2's Avatar
No, no, a thousand times no!!!! It will not work properly if you try to do that to a fwd car. It will not steer properly. You can get away with welding up the spider gears on a rwd car because the rear wheels do not have to steer the car. The inside rear tire will always slip a little though as the outside rear tire rotates faster than the inside rear tire when you turn. Differentials are there for a reason.
Old Mar 2, 2010 | 04:57 PM
glhs379's Avatar
i think they call that a lincoln locker!
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
importkiller
Sep 30, 2015 07:18 PM
Extremespeed
Sep 29, 2015 04:34 AM
