lsj and lnf put together?
i wanted to know if i could use the lnf block on a 07 but i know i cant used the head or the pistons from the lnf because of the whole direct injection. but can i used lsj pistons in the lnf block and put a lsj head on the lnf block?
O.O
That's a hell of a question man.
Lemme see if I can't find something out for you....
However, I don't think you can. I believe the head is built completely different as well because like you pointed out. The direct injection.....
Possibility of a pretty nifty thread though if the idiots of this site stay out of it.
*waits for Jimbo, 06Black, Area47, 06Blackg85ss and others....*
doubt hes on the + side of 800
slower, less boost and lower compression although TVS would benafit
oh ok cool
and yea i been between 440-460 putting boost up and down until i got a bad greddy boost controller and i over boosted the car and crack the block in the water pocket
ECOTEC BUILDERS GUIDE THIRD EDITION PG 29 states that all production ecotec blocks (L61,LSJ,LE5, and LNF) are safe between 400-800hp. for power levels beyond 800 use GMPP block XGH679
unfortunately overboosting throws all that out the window
Well they did
When will people actually learn that you can't put a horsepower rating on everything?
He told me what I relayed to you.
yeah arp studs and cometic gasket
did you read his post? using the LNF block with LSJ pistons and cylinder head. IIRC the lnf is a gen 3 ecotec block which is stronger in some areas
