LTFT and STFT question
So I've been searching the forum and I can't seem to find a definitive answer. I'm still learning about proper A/Fs, LTFT, and STFT on these cars so bare with me if this might be a novice question.
The other day I was logging my car with a scan tool a buddy of mine has, and I seem to be getting wacky fuel trims. My LTFT were right around -12, and my STFT were pretty good at WOT between -0.8 and 0.8, but just cruising around at highway speeds they seemed to be all over the place. I'm ranging somewhere between -6.7 and 6.3 just cruising around on the highway.. Is this normal? I will say that at WOT I am getting some great flow though @ 38lbs/min. I'm guessing I must be running super rich if my LTFT are in the -12s like that.
Anyone know if these numbers may cause any issues?
Your MAF is skewed by over +12% (indicated by the -12 LTFT) so in reality an indicated flow of 38 lbs/min is actually ~33.44 lbs/min. Your car is running very rich and the ECM is trying to compensate by spraying 12% less gasoline than was indicated as needed by the MAF sensor. You have an intake correct? If not someone messed with your MAF tables when they should not have. NM read your sig. Were you tuned with that intake on the car? If so you were not tuned for it. LTFT should be -1 to 0 and STFTs should be +3 to -3 on a well tuned car.
crap........
Catless DP will not cause a -12 LTFT. It is the fact that you were never tuned for that intake in the first place.
hmm.. I really hope that's not the case, especially seeing as how it was tuned by trifecta.
The car has never given me an issues with drivability, CELS, or any issues in general. Not to say that doesn't mean something funny wasn't going on that the car wasn't making me aware of. Would running a slightly higher octane fuel skew my fuel trims at all? In my tank at the moment I have been running a 10:1 ratio of 93 octane and 104 octane fuel, nothing crazy. So it's probably only a couple of points increase at most, but could that have any effect?
Iceberg
Sep 29, 2015 12:33 PM
