MAF codes, lack of boost, help!
Old Nov 10, 2012 | 06:21 PM
SSlobalt's Avatar
Originally Posted by sreid
I went to dealer. Over war retry for maf sensor. They tried a new maf first and road tested it after clearing CMDTCs. And popped codes again. So they put my sensor back in. I work for ford and can't pick up any data logs with my IDS scantool. I was thinking my checking the sensor voltages with the dealer pinpoint tests and hope for luck. But I heard injen causes problems a lot of the time. Ran boost leak tester. Quiet environment and can't hear any hissing with it holding 23psi in the piping an cooler without it dropping.
You can't always hear the hissing with the bumper cover on, though. Sometimes, you even have to get the soapy water (Snoop) after it.
Old Nov 10, 2012 | 08:12 PM
sreid's Avatar
I will try it again but I was under car and couldn't see anything or hear. But I'll try again. Sounds like the boost pressure is coming out the ass of the turbo. And I get a chatter noise on hard accel. Chirp noise happens and boost flutters.
Old Nov 11, 2012 | 10:02 PM
SSlobalt's Avatar
Do you have the soldered GMS1 sensors?
Old Nov 12, 2012 | 05:56 PM
sreid's Avatar
nope. im getting a lot of random building boost and not building boost. shifts even seem a little messed too some times.
Old Nov 12, 2012 | 06:21 PM
prevsrt4owner's Avatar
Cracked end tanks?
Old Nov 12, 2012 | 06:49 PM
sreid's Avatar
Dont see a leak. Holds 20psi in the system and doesnt drop any psi over 30minutes. pretty sure its holding pressure. could it be boost solenoid of some sort ?
Old Nov 12, 2012 | 08:17 PM
ATLsilverSS's Avatar
Subd.....mine just started doing the same thing 2 days ago...im throwing p101. Gonna take a look at everything tomorrow.
Old Nov 12, 2012 | 08:27 PM
Vacuum leak? Do a smoke test.
Old Nov 13, 2012 | 06:46 AM
SSlobalt's Avatar
The system isn't air-tight, so there's no way it can hold 20psi of pressure. I don't understand what you mean, here.
Old Nov 13, 2012 | 11:58 AM
sreid's Avatar
i made the boost leak tester in the other thread. put it on the top of the hotside cooler pipe. hooked air compressor to it, cauase my regulator is broken, i just put 25psi in the compressor. then hooked it up to the boost leak jig. once it hooked up it filled the system with pressure, and didnt drop on the compressor. nor was their hissing from any of the clamp areas.
Old Nov 14, 2012 | 02:29 PM
  #36
SSlobalt's Avatar
Ah. You need to have a working regulator on your compressor so that it isn't running while you're trying to hear leaks on your car.
Old Nov 14, 2012 | 04:23 PM
  #37
sreid's Avatar
filled compressor to 25psi. turned off compressor so it is dead quiet. then hooked up air line to fitting on boost jigger so there is no noise.
Old Nov 14, 2012 | 06:20 PM
  #38
SSlobalt's Avatar
I get you, now. I guess we can move on from boost leak, then. Pull your lower TMAP and see if it's oily.
Old Nov 15, 2012 | 03:52 PM
  #39
sreid's Avatar
k ill do that next.
Old Dec 13, 2012 | 04:32 PM
  #40
sreid's Avatar
checked lower map sensor. has little bit of white over the plastic part but nothing on the colored tip. no oil.
Old Dec 13, 2012 | 06:33 PM
  #41
SSlobalt's Avatar
What color is the o-ring on the sensor?
Old Dec 20, 2012 | 09:49 AM
  #42
sreid's Avatar
what color do i not want, what should it be, so i know what to look at when i get to hawl it back out. ramp in the garage is been busy been working a lot before christmas, never has a chance to put my car in
Old Dec 20, 2012 | 05:28 PM
  #43
SSlobalt's Avatar
If you have stock sensors, they should be blue/green. If you have GMS1 sensors, they should be black.
Old Dec 30, 2012 | 03:07 PM
  #44
sreid's Avatar
noticed on cold start says low coolant when its not low. aalso poped p0451 in pending codes. no engine light on. still never had chance over christmas to get a look at the color of the o-ring on the lower map
Old Dec 30, 2012 | 08:33 PM
  #45
mightymouse1975's Avatar
do you still have te stock air intake??? i would reinstall that and reset battery or reset with scan tool and try again.
Old Dec 31, 2012 | 04:14 PM
  #46
sreid's Avatar
do not have stock intake. has injen on it now
Old Jan 2, 2013 | 03:34 PM
  #47
SSlobalt's Avatar
Well, that's the EVAP code and will cause random boost issues, so replace the EVAP vent valve and the EVAP solenoid and see if that helps.
Solenoid:
Vent Valve:
Old Jan 4, 2013 | 04:41 PM
  #48
sreid's Avatar
do you think that would cause my maf codes ive been getting and the flutter in turbo? also have noticed gas gauge speratic of a 1/4 tank sometimes,.
Old Jan 4, 2013 | 05:08 PM
  #49
SSlobalt's Avatar
MAF codes can be caused by any vac leak. You had a code for the vent valve so I would say it's worth a shot
Old Jan 20, 2013 | 07:01 PM
  #50
sreid's Avatar
installed new purge solenoid and vent valve. valve required me to buy a new harness because they changed the valve and connector. erased codes, see how it goes, so much snow out cant get car out.
