Massive Misfire When WOT
It Just started tonight, I gave my car the work yesterday...
Seafoam, Oil Change, Spark plugs (stock AC Delcos .35 gap) And checked for all and in boost leaks...
The car run good until tonight... I get on it in WOT thru the Baltimore Tunnel And Just gun fire sounds.. The interceptor reads 41 misfires....I;m instantly worried... When driving normal and idle no issues, So i get to my girls house, and Swap in my hold spark plugs...Try to got WOT again Same thing 15 misfires...
I try to reset the ECU and when I start it, it has issue cranking, it eventually cranks over...
Now it doesnt misfire when im partial Throttle, I got it all the way to around 10 psi Partial...Just WOT...I thinking its my HPFP..
WHen i was at the track 3 weeks ago and NLS from 3 to 4 the code for the Fuel pump performance came up..but never again.. I have a HPFP headed down... I'll keep you posted...
Any ideas, suggestions, or comments would be great Thanks!
did u run all the seafoam out of the system? when i seafoam i cant get on it for awhile till its all out. i get misfire and junk to. just drive nice till its gone then open it out. just wondering if u did
Yea its definetly all out, this is a massive misfire... Sounds like gun fire, no power either..Only when WOT tho
I just ordered a injector seal kit, gmparteast
Yea I hope not, I thought I had everything perfect now this, and my sportline snapped this weekend... so after reading I. Am broke's post seems like the injector seal, right after I seafoamed...
You think I might need a intake mani gasket?
I had the exact same issue. I did the same things as you but without the seafoaming. Afterward, torque seemed down and at WOT I got massive backfire.
Soccer helped me with mine. When I bought the plugs, I was guaranteed by the auto parts store that the plugs I were buying were pregapped. I even looked at it with them on their screen to make sure it was the right engine and so forth. I didn't want to gap them because I know on some plugs it's bad to scrape them with metal gapping tool.
Anyway, they were all gapped differently. After I got them all to .030 everything was perfect and has been since. Soccer set his at .028. I don't know if that's due to colder plugs or higher boost levels or what. Hopefully someone who knows about this stuff will chime in.
It wouldn't take long to check the gaps though.
I seriously doubt its gap, But i'll try it when i get home, I use my old plugs which worked fine before...Only thing i can think of is the injector seal the symptoms match... I'll do the gap when i get home.. I really dont think its the gap tho
Startingline, If your right...Imma be pretty mad i order all those parts....We'll find out around 6 when i get off...I wish had tools i'd do it in my jobs parking lot LOL
Well if it is your problem then it's a very easy fix
then you will have extra parts when needed in the future. If not then try other things. I would just think if you had seals leaking or a gasket leaking you would have a high idle too.but a lot of us go through these problems too and we are all here to help, that's why this form is awesome
Yea the idle isnt high, vaccuum is good.. Why the hell would it just start having a spark blow out all a sudden...
yea you guys have been pretty helpful i must say.
