Massive Misfire When WOT
Old Apr 9, 2012 | 11:52 AM
startingline05's Avatar
Originally Posted by Kbbalt
Yea the idle isnt high, vaccuum is good.. Why the hell would it just start having a spark blow out all a sudden...
yea you guys have been pretty helpful i must say.
Cause you changed the spark plugs and prob didn't check the gap.
Old Apr 9, 2012 | 12:00 PM
blk06ss/sc's Avatar
my stock plugs were .032 started getting misfires around 22k swaped the plugs n shes all good again, I left the gap the same
Old Apr 9, 2012 | 01:40 PM
Kbbalt's Avatar
Still doesn make any sense, It was driving fine an boosting then all of a sudden..Snap Crackle and Pop out of the exhaust..
Old Apr 9, 2012 | 01:59 PM
Frogstofall's Avatar
Personally, if your car sounds as bad as the one in the video, it ain't your plugs. For your sake, I hope it is tho.
Old Apr 9, 2012 | 02:11 PM
FasterIsBetter's Avatar
Eh, even if it is seals, it should only cost him around $100 and I'd sell him my injector tool cheap if he really needed it.
Old Apr 9, 2012 | 02:15 PM
Kbbalt's Avatar
Not as hardcore as that, But yes, when it WOT, SOunds like gun shot and misfires... I brought the tool, injector seal kit, and intake mani already... just waiting...Going to try to reduce the spark plug gap tonight...I wanna race my buddies Golf R.
Old Apr 9, 2012 | 02:54 PM
Yeah that's kinda what I was hinting at.
Take pics Kbbalt. Also, Golf R should be no problem.
Old Apr 9, 2012 | 02:58 PM
Kbbalt's Avatar
I'll snap some photos
Meanwhile, I contacted bfross, the guy with the vid and he figured his problem out
"Yes I did actually. Turns out I had a boost leak on the vac line going from the boost controller to the wastegate"
We dont have boost controllers... So maybe some kind of Vaccuum Leak? I need a diagram...
Old Apr 9, 2012 | 03:18 PM
"Yes I did actually. Turns out I had a booust leak on the vac line going from the boost controller to the wastegate"
He has a Treadstone turbo kit. And we do have a boost control solenoid located on the stock turbo.
elecblue06's Avatar
i had crazy blowout and my car sounded pretty bad.. not as bad as that video but definitely like a gun shot. turned out I was missing a good portion of the diode on cyl 4's spark plug and all the plugs opened up to like .45+
Old Apr 9, 2012 | 03:29 PM
  #36
Kbbalt's Avatar
Looks like this is going to be a whole lot of trial and Error....
Old Apr 9, 2012 | 08:30 PM
  #37
Kbbalt's Avatar
Done..she's back!!!!!....
You guys ready for this? Put in the new plugs again reduced the gap to 0.32
Still no good....then I replaced the spark plug boots one at a time.. the one on cyclinder 4 was bad.... fixed..
Old Apr 9, 2012 | 09:07 PM
  #38
Nice!! Also, are you on E at all?
Old Apr 9, 2012 | 09:37 PM
  #39
Kbbalt's Avatar
No E 93 pump
Old Apr 9, 2012 | 10:27 PM
  #40
DillySS's Avatar
I would also check the gap. It sounds like spark blow out. I gapped mine from .35 - .32 to see what the best fit was and I'm at .32. Not all cars are the same. I thought .35 was fine until I got more boost.
Old Apr 9, 2012 | 11:01 PM
  #41
Ah, well, sucks you ordered all that stuff, lol!
Old Apr 10, 2012 | 07:36 AM
  #42
mongorat427's Avatar
Refund sent for HPFP. Glad you got her fixed
Old Apr 10, 2012 | 10:22 AM
  #43
Kbbalt's Avatar
Still Misfires when i NLS... i might reduce the gap more...Other than she is Pulling Trainstations on people!
Old Apr 10, 2012 | 01:29 PM
  #44
elecblue06's Avatar
you're not doing it fast enough then
Old Apr 10, 2012 | 02:09 PM
  #45
Kbbalt's Avatar
Lol you think? Im usually pretty good at it, I'll try it again.. I got 41 misfire when i tried it this morning once i got to work...
Old Apr 10, 2012 | 02:48 PM
  #46
elecblue06's Avatar
i mean idk for sure but I know that was a common problem when people first got the car and had it tuned they weren't doing it fast enough
Old Apr 10, 2012 | 04:10 PM
  #47
Kbbalt's Avatar
Worth a try, Im going to Degap and try to do it faster on the way home!
Old Apr 10, 2012 | 05:34 PM
  #48
Just don't miss a gear! Bad things always happen when you do that, lol.
Old Apr 10, 2012 | 05:59 PM
  #49
Kbbalt's Avatar
Hahaha just got home....looks like I wasn't doing it fast enough...my granny shiftiing ass
Old Jun 6, 2012 | 11:37 PM
  #50
AARON-SS-TC's Avatar
so, if the seals were going then the car would idle rough or high?
At wot, my car did this tonight in high rpms or right after i shifted,loss of power/misfire... so it may be the plugs? they only have like 5k miles on them"
last time i had misfires, it was my purge solenoid that went bad. i could completely blow through it..that was only 1k miles ago
