max speed in each gear
so road and track says cobalt ss/tc will top at 69 in 2nd gear, 105 in third gear??!! seems more like 60 and 100 to me unless i'm doing something wrong. shifting at redline??
But I have yet to get 69 mph in 2nd gear
For 225/40/18 tires, with the gear ratios of the ss/tc, the theoretical top speeds are
6300 rpm
1st 36
2nd 70
3rd 104
4th 138
5th 176
This is all mechanical, so if you can't go faster than 60 in 2nd gear, you just need to push the gas harder.
6300 rpm
1st 36
2nd 70
3rd 104
4th 138
5th 176
Why must you post a duplicate of your other thread, made the same day, yet 16 hours apart?
My redline is 6800 so I go 37 in first, 70 in 2nd, 109 in 3rd and 14X in 4th... I've yet to find out about 4th gear as the car seems to hit a brick wall up there despite 290 whp.....
I really dont feel this thing will go faster then 150..... Not enough power\gearing to push 2950 lbs throught the air that fast......
Your gear speeds are the same that Hahn has for their Ss\TC with a 7000 RPM redline in 1-st and 2nd but 3rd gear to 5th in their car is back to 6300 rpm and Hahns car only hits
100 in 3rd... He says he goes throught the 1\4 in 4th, which is true... Now that I've a 9800 rpm redline 1-5th I can clear the 1\4 in 3rd and run 109-110 mph trap speeds...
We'd need well over 350 whp to get the car (SS\TC) to it's theroretical top speed...... My 2006 GTO's 6th gear was a economy gear but that gears hypothetical top speed is 223 mph...I'd need over 880 whp to hit that mark,,,,,
You must have a higher magical redline then 6300rpm, when stock my car flatens out on the 6300 rpm redline at 61 mph and 99-100 in third gear with stock 225/35/18's SS\TC.
Oh, and good job with posting 7 replies.
Also, stock tires are 40 series, not 35.
I think he means in calculating the theoretical top speed in each gear. In other words, factoring out power, drag, etc. and just focusing on the gear ratios and engine limitations.
With a 6800-7000RPM redline, Yes the car will hit 69 in 2nd and 105 in third...... Stock redline, ... you are correct, about 62 in 2nd and 100 in 3rd.....
the mechanical top speed is the same regardless of any other conditions. You may not be able to get to the top speed in each gear, but mechanically, the top speed doesn't change.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ThoR294
Oct 4, 2015 08:44 PM
