is meth dangerous ?
Old Oct 23, 2012 | 11:19 PM
BEG4MRC's Avatar
is meth dangerous ?
i have a 2009 cobalt ss with 3inch down pipe snow performance meth kit level 5 nozzel k&n intake and hp tuned i run 22 degrees timing 22 lb of boost
Old Oct 23, 2012 | 11:21 PM
Meth is very addictive. Just stick to drinking
Old Oct 23, 2012 | 11:22 PM
09BlueBaltSS's Avatar
Only when it stops spraying mid run and u don't realize it. At least you are not running real high boost (24+psi)
Old Oct 23, 2012 | 11:23 PM
BEG4MRC's Avatar
is it safe lol
is ther a lot of motor that let go from it lol i want to run e85 but i dont no about the 5the injector
Old Oct 23, 2012 | 11:25 PM
Ever thought about e47?
BEG4MRC's Avatar
one time it did stop lol
one time it stop and i got 8 knock so i invested into a fail safe from snow if the meth stops it pulls 10 lb of boost
Old Oct 23, 2012 | 11:26 PM
nhanson's Avatar
E47!
Old Oct 23, 2012 | 11:27 PM
BEG4MRC's Avatar
i would like to run full e85 i dont like the mixing lol
i have just sounds a little much for a dd
Old Oct 23, 2012 | 11:33 PM
Does it stop the car from knocking? The ignition advance is the danger not the boost
Old Oct 23, 2012 | 11:39 PM
BEG4MRC's Avatar
yea meth does
yea meth does
Old Oct 23, 2012 | 11:40 PM
No he's asking about the safety switch
Old Oct 23, 2012 | 11:45 PM
BEG4MRC's Avatar
good point
thers also a led that flashes in my face if it dont spray i dont no about the boost being pulled i just need to do a zfr on pump only make 360 wheel call it a day if only i had 2000 $$$$
Old Oct 24, 2012 | 11:26 PM
SSlobalt's Avatar
If you're running 22 degrees of timing without meth or E47, you're driving a time-bomb.
Old Oct 24, 2012 | 11:41 PM
nhanson's Avatar
I think he meant he has it on now.
Old Oct 25, 2012 | 12:05 AM
Pedobear's Avatar
makes sure its crystalline before use
Old Oct 25, 2012 | 12:26 AM
tomj77's Avatar
i wouldnt run it if i was u. if u do either do it just for intercooling and keeping valves somewhat cleaner, or make sure u get every safty system u can for it lol. but im paranoid
Old Oct 25, 2012 | 09:44 AM
CudaJoe's Avatar
over use of meth will harden the veins and you will end up with nasty looking arms.
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
