METH Injection
Old Jul 31, 2010 | 01:17 AM
D-mac's Avatar
METH Injection
Thinking of adding Meth injection to my setup
Other mods are listed in my Sig
Im liking the Devils Own progressive kit
What are you guys thinking of going with Meth? Where are you putting the Nozzle?
How easily can BYT tune for this via HPT?
Lots of good mounting locations to keep it away from the eyes at a dealer?
Thanks
Old Jul 31, 2010 | 01:23 AM
MP Cobalt's Avatar
Yes meth will help you out. Tuning for meth is like anything else if they can tune for it. If you plan on taking it i for warranty work and are worried about them seeing it. that won't happen lol
Old Jul 31, 2010 | 08:58 AM
Iam Broke's Avatar
Inject it just after the IC outlet in the lower CP. 3 gph or 5 gph nozzle depending on your setup. BYT can prob tune the 5 gph for you ok. Ask him, he's tuned others.
I like the AEM trunk mount or if you are going to use the washer fluid tank the Devil's Own looks good.
Old Jul 31, 2010 | 11:02 AM
MP Cobalt's Avatar
devilowns can be mounted in the trunk also?
Old Jul 31, 2010 | 11:09 AM
smthomas556's Avatar
Buy my kit thats for sale.
Old Jul 31, 2010 | 11:34 AM
D-mac's Avatar
Once i hear back from BYT i shall
Just wanna make sure i can spray it safely without squewing my MAF
Old Jul 31, 2010 | 12:04 PM
Iam Broke's Avatar
As long as your MAF is in the K&N intake location, I don't see any problems. I can't spray meth in the lower CP as my MAF is right ahead of the TB and would get soaked.
Old Jul 31, 2010 | 12:39 PM
D-mac's Avatar
Lower CP is still stock so i cant put a nozzle in plastic
MAF is in the K&N SRI
Do i need an aftermarket lower CP?
Old Jul 31, 2010 | 12:45 PM
iboost's Avatar
no u dont NEED aftermarket pipes. i did thought
Old Jul 31, 2010 | 12:58 PM
D-mac's Avatar
Once i find out where to mount a nozzle and BYT chimes in about a tune then i will buy
Old Jul 31, 2010 | 02:25 PM
Iam Broke's Avatar
I would think you can tap a nozzle into the hard plastic of the stock lower CP. I'd epoxy the sucker also though. Won't be as close to the outlet of the IC, but it'll work. The reason it's best to keep it as close to the outlet of the IC as possible is to give the spray time to mix & disperse into the airstream so all 4 cyls see the same mix.
Old Jul 31, 2010 | 03:10 PM
Contact fface. He can send you pictures of his setup. I helped him with the install.
Old Jul 31, 2010 | 04:55 PM
FF_ace's Avatar
^^^ ya he helped me with my install its very clear if you need any help or pics of the install just let me know
Old Jul 31, 2010 | 08:53 PM
09CobaltSS1's Avatar
I'm sure BYT will answer you better when he sees this thread, but I can assure you that he will be able to tap into the stock lower charge piping with no issues.
Old Aug 1, 2010 | 12:29 AM
D-mac's Avatar
Sent ya a PM
Old Aug 2, 2010 | 09:29 AM
BYT*SS*TURBO's Avatar
You can hide it OK but if the dealer looks in there they will likely see it. I wouldn't plan on doing this and then also plan on bringing it in for warranty work. You can always mount the nozzle on the bottom side of the lower CP so you can insert a plug and remove the line when bringing it in, then hope for the best lol.
Easy to tune for If you do remove it to goto the dealer, just flash the no meth file back to the car and you're set. OR Stock file lol.
Old Aug 2, 2010 | 10:15 AM
slowbalt84's Avatar
or have an extra intercooler pipe to switch back one without the nozzle hole in it
Old Aug 2, 2010 | 11:49 AM
D-mac's Avatar
Would it be best to run an aftermarket lower metal pipe?
Cause i already have to swap out my Map Sensors to take it to the dealer so i could leave the stock plastic one ready to swap back in
Can get a CIA one for a really good price and then just swap back my stock one for the dealer?
Any issues with the CIA pipe?
Old Aug 2, 2010 | 11:56 AM
ColeJJones's Avatar
Bannned
I run the cia pipes with my meth kit. Really strong for threading
Old Aug 2, 2010 | 12:26 PM
ISuckBad45's Avatar
what type of power increase are you seeing with the Meth kit on factory turbo?
Old Aug 2, 2010 | 12:45 PM
FF_ace's Avatar
w
I emailed you the pics of my kit did you get it. I'm running cia charge pipes with my kit
Old Aug 2, 2010 | 03:55 PM
w
Thanks Nick!
Old Aug 2, 2010 | 04:01 PM
Lower CP isn't really needed but since you have to remove the stock one it wouldn't hurt to replace it at the sametime! I would just skip the Maf Relocate unless you buy a Maf mount and mount it yourself to allow proper distance from the Meth nozzle!
Old Aug 2, 2010 | 04:14 PM
Terminator2's Avatar
It is going to depend heavily on the quality of the gasoline used to begin with (octane level and percentage ethanol) and the tune (boost level, timing, A/F, etc) itself but 15-20 whp normally.
Old Aug 2, 2010 | 05:00 PM
D-mac's Avatar
Went ahead and got that CIA lower pipe so i can leave my stocker alone
Better to thread into metal then plastic also
15-20 WHP is definitely worth the cost of the kit and the cooling affect is also nice
