meth kit mount
Old Mar 11, 2011 | 06:25 PM
tomj77's Avatar
meth kit mount
for those who have done a trunk mount meth kit, where did u run the tubbing? and is it ok to use the black flexible tubing instead of the ridged crap u get with? if someone has pics that would help
Old Mar 11, 2011 | 06:46 PM
Gunney_07's Avatar
I ran the tubing through the upper front of the spare tire well. From their to over the evap canister, then to the frame rail and followed the fuel/brake lines to the front engine cradle. Then from from frame rail across inside of the engine cradle to the lower cold side charge pipe where I'm tapped in.
Old Mar 11, 2011 | 07:16 PM
iboost's Avatar
check my cardomain in my sig. Go to page 4. I have install pics of my meth kit. Basically mounted the bottle on the right side. Drilled a hole. Ran the line given through a bigger line for protect. Followed underside of the car up to the cold side charge pipe
Old Mar 11, 2011 | 07:28 PM
cmiller8006's Avatar
I just ran the line through the car lol. As long as you check for leaks your fine I was told. Put mine where the spare would go.
Old Mar 11, 2011 | 08:20 PM
tomj77's Avatar
crap i kinda wanna keep the spare tire in there. may need it one day. what did u seal the holes with?
Old Mar 11, 2011 | 08:24 PM
SSlobalt's Avatar
Didn't someone mount one of these in place of there windshield wiper fluid bottle?
Old Mar 11, 2011 | 08:29 PM
Iam Broke's Avatar
You can use the Devil's Own kit with the WWF bottle. If I put one on, that's what I'll do but it will mean pulling the bumper again to get at it.
Old Mar 11, 2011 | 08:34 PM
SSlobalt's Avatar
Was it Gestapo that did that or was it someone else? I can't remember.
Old Mar 12, 2011 | 12:54 PM
MastaShaKe_88's Avatar
click
Old Mar 12, 2011 | 02:16 PM
tomj77's Avatar
u guys think the plastic liner at the back of the trunk would hold a full tank if i mounted the tank there?
Old Mar 12, 2011 | 02:52 PM
tomj77's Avatar
ya im gonna be in contact with u when i have questions, i like the way u did it, so ill do it that way, guess ill start with the mounting bracket u made. gotta have that. thanks.
Old Mar 12, 2011 | 03:01 PM
Mongorat did the washer tank I think.
Old Mar 12, 2011 | 06:41 PM
do you have to put it in the Spare tire spot tho? Or the windshield washer tank?? those the only options??
If/when I gets a kit, cant I jus Mount it in my trunk off to the side or somethin an run the wires down??
Old Mar 12, 2011 | 07:26 PM
You can mount the tanks whereever you want.
Old Mar 12, 2011 | 08:01 PM
Gunney_07's Avatar
Just make sure if the tank is mounted higher than the spray nozzle to have a check valve. But it a good idea to have one any who.
is that a flow meter t'd into the line i see? And if so what make and how much $$$$?
Old Mar 12, 2011 | 08:41 PM
tomj77's Avatar
where do u get a check valve
Old Mar 12, 2011 | 08:44 PM
Gunney_07's Avatar
Methanol Injection Check Valve Devilsown
here is an example, other companies make them too you'll have to compare pro's con's yourself. But i have a complete kit from Devils own and it top notch and great customer service!
Old Mar 12, 2011 | 08:51 PM
well why does everyone mount em in one of those 2 spots then?I've seen No2 tanks mounted everywhere, but Meth's always in the same spots....
Old Mar 12, 2011 | 08:57 PM
cobaltsssc760's Avatar
i mounted mine on the side came out sick
i would show you but it wont let me post a pic on here
Old Mar 12, 2011 | 08:58 PM
Yea that was a flow meter/failsafe from coolingmist.
Old Mar 12, 2011 | 09:01 PM
ImageShack® - Online Photo and Video Hosting ...
I was jus wonderin tho... cuz I've been in a couple spots with my old car where I had to throw my spare on at a horrible time, or times where I wish I would've bought a spare
Old Mar 12, 2011 | 09:38 PM
still wont let me post which link should i use?
Old Mar 12, 2011 | 09:40 PM
not to thread jack but idk how to post pics i have a link to my pictures https://www.cobaltss.net/forums/pict...ctures-197655/
Old Mar 12, 2011 | 10:01 PM
Gunney_07's Avatar
my setup is not as pretty as his --^,but just as functional lol.
Old Mar 12, 2011 | 10:17 PM
exactly!!! s wat i wanted to see^^^ my comps runnin slow cuzza MVC3 so I cant see dudes page.. but thats watt Im talkin bout ..
